Old 03-29-2017, 12:53 AM   #1
wesmigletz
wesmigletz's Avatar
Want to upgrade to a BBC 4 core radiator, what is needed?
Looking to upgrade a 76 C10 to a BBC four core radiator. The truck currently has the stock 350 engine and stock radiator.
Will I need anything else besides the following parts?
Upper mount panel
https://www.brotherstrucks.com/75-80...tinfo/RSC8003/
BBC Shroud
https://www.brotherstrucks.com/73-87...tinfo/FS07387/
New rubber pads
https://www.brotherstrucks.com/73-91...tinfo/RRP8704/
New radiator mounts
https://www.brotherstrucks.com/73-80...tinfo/RSM8001/
Thanks in advance,
Wes
1970 2WD K5
1968 Camaro Conv
1967 Chevy SWB
1964 Malibu SS
1957 Corvette
Pics
www.picturetrail.com/wesmigletz
wesmigletz is offline   Reply With Quote
Old 03-30-2017, 12:18 AM   #2
El Dorado Jim
Re: Want to upgrade to a BBC 4 core radiator, what is needed?
you wont need the core support mounts to install your new radiator.just the shroud, upper mount panel and the rubber pads...you got it covered,
El Dorado Jim is offline   Reply With Quote
Old 03-30-2017, 03:14 AM   #3
wesmigletz
wesmigletz's Avatar
Thank you for the confirmation. Sounds like a straightforward swap
Old 03-30-2017, 09:38 AM   #4
KQQL IT
At the body shop.
KQQL IT's Avatar
And possibly nut serts for the top of the core support.
My 77 wasn't threaded on the topposite of the core support.
KQQL IT is online now   Reply With Quote
Old 03-31-2017, 12:23 AM   #5
El Dorado Jim
x2, forgot to mention that in my post, I had to install nutserts...
Old 03-31-2017, 10:18 AM   #6
wesmigletz
wesmigletz's Avatar
Thank you for the confirmation about the nutserts, I will plan for them
Old 03-31-2017, 11:50 AM   #7
KQQL IT
At the body shop.
KQQL IT's Avatar
3/8 x 16 where a perfect fit.
Old 03-31-2017, 12:08 PM   #8
wesmigletz
wesmigletz's Avatar
Old 03-31-2017, 12:23 PM   #9
DieselSJ
You will get better cooling with a modern 2-core aluminum replacement. Instead of 4 small rows, they have 2 big rows. Air flows through them better and they have a better BTU rating. Even the cheap alum/plastic replacements from your local chain auto parts will work. I have one in my dually cooling my 454 and I have no issues keeping things cool while towing with the A/C on in Phoenix in August.
87 R30 CC Dually, TBI 454, NV4500, zero rust barn find
87 Jeep Grand Wagoneer, 6.5 turbodiesel, 700R4
DieselSJ is offline   Reply With Quote
Old 04-02-2017, 02:28 PM   #10
PEDROSKI
PEDROSKI's Avatar
Spectra Cu730 radiator is a direct replacement for the 454. Works great
72 2wd k5 blazer
86 c10 "Red",76 2wdK5 "Bertha",77 2wdK5 "48",79 c10"Buster" GONE
Old 04-02-2017, 04:30 PM   #11
KQQL IT
At the body shop.
KQQL IT's Avatar
I have one in my '73 it wasn't perfect, was just a shade to tall made the shroud all wonky.
