65 c10 lowering block question
I was talking to a guy and he was telling me he has seen guys run 4 inch lowering block on trailing arms. I thought 4 inch blocks was a little excessive but has anyone seen this? If so, im thinking about trying it. Ive got 22's and a thorbros notch. This would be on a bag setup. Any info is appreciated.
Posted via Mobile Device Last edited by Capo_Customs; 04-22-2017 at 12:34 AM. |
![]() Join Date: Aug 2014
Re: 65 c10 lowering block question
I believe most people will only use 1.5 to 2" blocks. I've never even seen a 4" block for sale. Depends to on scrub line, what size wheels you have. With 15" wheels most will say 1.5 is the most due to if you had a flat tire the arm would bottom out.
1965 C10 LS2/4l70, WHITE, 5/7 DROP LINK TO SUPER SNOOPY C10 BUILD---> http://67-72chevytrucks.com/vboard/s...d.php?t=689283 1977 C10 SILVERADO HAWAIIAN BLUE, 5/5" DROP, LS6/4L80E 1976 CHEVY K5, 350/350, YUBA GOLD/SADDLE |
![]() Join Date: Jan 2011
A block also pushes the wheel forward with a set of trailing arms. With the wheel already looking to far forward with the wheel opening location that would compound the issue.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
