Old 05-01-2017, 02:25 PM   #1
Chevystep
The order of things...??
Well, the engine is back in the 66 AND running, so I'm going to start slapping on fenders, grills and other stuff on the front of the old girl. Any order that others have done, more importantly, what NOT to do first as sheet metal gets bolted back on up in the fender/front grille area?
Chevystep is offline   Reply With Quote
Old 05-01-2017, 04:25 PM   #2
forestb
forestb's Avatar
Re: The order of things...??
correct me if I am wrong but I would say cor support, inner fenders, grill surround, outer fenders and then hood. I would guess that you should leave everything a little loose until it is all lined up.
forestb is offline   Reply With Quote
Old 05-01-2017, 05:15 PM   #3
scoot_mcgrute
I did mine last year as inner fenders, core support, fenders, grille piece and lastly the hood.
Did an LS swap and pulled the front clip this year and I put the inner fenders and core support on as one unit and the fenders and grille piece as one unit. Both worked ways worked well for me.
1966 Army Truck
http://67-72chevytrucks.com/vboard/s...d.php?t=691778
scoot_mcgrute is offline   Reply With Quote
Old 05-01-2017, 06:08 PM   #4
Clyde65
Clyde65's Avatar
One thing I didn't do when I did my LS swap was cleanup and paint the firewall, wish I would have done it then. Clean clean clean as you go though. Power spray your frame.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
