Old 01-07-2013, 09:43 PM   #1
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Let's see your - Metal Tube Radiator Hose
Curious who has built their own radiator hose out of metal tubing and what you used to make it.
What type of tube did you use?
What type of end clamps did you use?
Hose ends?
Exhaust tubing?
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 01-07-2013, 10:00 PM   #2
LSUMurse
LSUMurse's Avatar
Re: Let's see your - Metal Tube Radiator Hose
I am new to this and apologize for asking a question instead of giving an answer but....
What's the benefit/purpose to metal radiator hoses? Aesthetic?
I'm just trying to wrap my head around it, I've never seen something like that.
It's not that I am apathetic, I just don't care.
If your life is a joke, it appears death will be your punchline.
LSUMurse is offline   Reply With Quote
Old 01-07-2013, 10:03 PM   #3
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
I don't have one but IIRC some if not all 4X4's had a metal upper rad hose.They were used on them to keep a flopping hose out of the fan I guess.Not many left.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 01-07-2013, 10:23 PM   #4
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Mainly for aesthetics and to clean things up. A great addition when you have added unique touches under the hood.
Not sure on that one PD.
I know safety comes first. Either placing a weld bead line around the ends to create a radius around the tubing, or whatever, make sure the hose doesn't have a blow out when under pressure.
-Nate
Old 01-07-2013, 10:28 PM   #5
dialric
dialric's Avatar
Please note that you must be a supporting member to post classified items. This includes but is not limited to What Its Worth, Want To Buy, Want To Trade, and For Sale. Please consider supporting the forum by subscribing. Further information on the subscription levels available are located here
If you need any further assistance with that please contact any Admin for help.
dialric is offline   Reply With Quote
Old 01-07-2013, 10:34 PM   #6
shawno72
C/10 junkie
shawno72's Avatar
I was thinking of making one for my truck at work. Bend some correct size exhaust pipe and flare the ends. The pipe is aluminized steel so it won't rust very easy plus you can paint it or powder coat it.
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline   Reply With Quote
Old 01-07-2013, 10:36 PM   #7
hot trux
'85 Stepside
hot trux's Avatar
it's a aluminum spreader bar from a cargo box.(tractor trailer) As long as it is 1 1/2'' is the main thing ,you can use exhaust tubing and weld a bead around each end to prevent slippage.
hot trux is offline   Reply With Quote
Old 01-07-2013, 10:43 PM   #8
72BlckButy
Tot Roddin'
72BlckButy's Avatar
I never get tired of looking under that hood hot trux...
That is exactly what I'm looking for.
-Nate
Old 01-07-2013, 10:47 PM   #9
Andy4639
Old member
Andy4639's Avatar
Wink Re: Let's see your - Metal Tube Radiator Hose
Here is mine. Aluminum Conduit I cut. The only problem is it's heavy and it keeps cracking the solder joint on the upper radiator neck. I have it tore a part and plan to have it rebrassed and see what I can come up with to releive the stress on it. I haven't had any problem with it sliding out of the rubber hose ends. I scuffed them up real good before inserting them.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 01-07-2013, 10:49 PM   #10
72BlckButy
Tot Roddin'
72BlckButy's Avatar
What rubber tubing are you guys using? Cutting up another hose? Using straight pieces and bending the tube?
-Nate
Old 01-07-2013, 10:49 PM   #11
Andy4639
Old member
Andy4639's Avatar
Attachment 1037741
That 2nd picture doesn't have any kind of clamps on the hose. Was that picture took test fitting it. Just wondering. loy nicer engine than mine to!
Old 01-07-2013, 10:52 PM   #12
Andy4639
Old member
Andy4639's Avatar
Cool Re: Let's see your - Metal Tube Radiator Hose
I used the old hose for the ends when I replaced it with the pipe. I bent my pipe but the hose ends can be used for that also.
Old 01-07-2013, 10:52 PM   #13
sdailey
The Few, The Proud
sdailey's Avatar
Here you go Nate. This is on a local truck. He used exhaust pipe. One short straight section and one 90.
Shannon
sdailey is offline   Reply With Quote
Old 01-07-2013, 10:53 PM   #14
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Yep... that's in his garage.
-Nate
Old 01-07-2013, 10:54 PM   #15
72BlckButy
Tot Roddin'
72BlckButy's Avatar
That is nice and clean; thanks for posting that buddy!
-Nate
Old 01-08-2013, 08:34 AM   #16
68Stepbed
68Stepbed's Avatar
Thanks for bringing this subject up, Nate. I need to do something like this on mine. Since the LS1 swap, the only negative I get is about my upper hose.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 01-08-2013, 08:56 AM   #17
rsavage
rsavage's Avatar
You are correct. 4 X 4's came with them.
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 01-08-2013, 09:37 AM   #18
jaros44sr
jaros44sr's Avatar
Bought these mandrel bent pieces from griffiths radiator on line. They are 45s and 1 3/4" , for my lower pipe, then just connected with strait hose. Pipes about 20 bucks apiece
20130108_082930 by jarosaj, on Flickr
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 01-08-2013, 10:39 AM   #19
mgkgmc
mgkgmc's Avatar
Anyone running stainless tubing?
1970 GMC 1500 stepside
1972 GMC Jimmy Custom
2004 Chevy Colorado
1989 Swb Silverado
1972 Aj's Stormer
mgkgmc is offline   Reply With Quote
Old 01-08-2013, 10:46 AM   #20
BMERDOC
BMERDOC's Avatar
FWIW, Matco has a bead roller for tubing. I saw it on Horsepower Tv...Haven't found it again since then.
Nick Carter
1967 C10 Short bed Fleetside
Project Cheap Thrills!
2WD C10 Modern/Performance Alignments
Easiest Alignment Ever!
BMERDOC is offline   Reply With Quote
Old 01-08-2013, 11:10 AM   #21
crawdadfox
crawdadfox's Avatar
Location: New Orleans Louisiana.....a great place to visit but you wouldn't want to live here!!!
Heres one from Hazel...
Down......with the sickness!!
crawdadfox is offline   Reply With Quote
Old 01-08-2013, 11:25 AM   #22
67cheby
67cheby
67cheby's Avatar
tuned in i want to do the same thing to Cloud 9
67cheby is offline   Reply With Quote
Old 01-08-2013, 11:46 AM   #23
~Whitey~
~Whitey~'s Avatar
another sweet mod for cleaning things up a bit. Thanks for posting about this... I will do this to mine when I get to that stage.
Jimmy
.69SWB Build.
~Whitey~ is offline   Reply With Quote
Old 01-08-2013, 11:52 AM   #24
Sammy
This IMHO much better than the aftermarket over priced custom stuff out there. A powder coated custom for your application makes sense.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 01-08-2013, 02:33 PM   #25
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Well get on it Matt and let me know how to do it. Haha!
That is quite a radiator hose you have under the hood.
I never would have guess that this was stock from the picture.
I knew "the man" had done this on his trucks in the past just couldn't locate a picture on my computer last night. Thanks for posting crawdad!
-Nate
