Old 05-14-2017, 08:32 PM   #1
sackracing
sackracing's Avatar
HEI Conversion
Since I only know fuel injection and electronic ignition, I'm struggling with getting my 283 / 2bbl / points ignition running smooth. Thinking about swapping to HEI. Is there a complete kit available for this, or what parts should I look for?
sackracing is offline   Reply With Quote
Old 05-14-2017, 08:43 PM   #2
ho70
ho70's Avatar
Re: HEI Conversion
Various manufacturers sell a pigtail to connect to a HEI
Here is classic industries one for $30
Product # CT39694
http://www.classicindustries.com/sho...k/parts/?q=hei
ho70 is offline   Reply With Quote
Old 05-14-2017, 08:50 PM   #3
72LB
72LB's Avatar
Re: HEI Conversion
It's pretty straightforward, This will help. http://chevellestuff.net/tech/hei.htm
72LB is offline   Reply With Quote
Old 05-14-2017, 08:55 PM   #4
truckster
truckster's Avatar
Re: HEI Conversion
It's the simplest and best upgrade you'll make. Just remember you need a full 12v for HEI; the points ignition uses a resistor to step down the voltage to conserve the points.
truckster is offline   Reply With Quote
Old 05-14-2017, 10:07 PM   #5
68GRNK20
68GRNK20's Avatar
Re: HEI Conversion
for those that have it how is your clearance with the firewall? My truck came with an HEI in it but it seems super close, I havn't started my truck to see how much it moves around
68GRNK20 is offline   Reply With Quote
Old 05-14-2017, 10:14 PM   #6
jocko
jocko's Avatar
Re: HEI Conversion
C'mon, points are FUN! It's a good skill to learn to set them - but, very true that for a daily driver, it's just hard to beat an HEI, practically maintenance free and no degradation in perf (like as when points burn down). I've not done the conversion to HEI, but I'm gonna follow along and listen in. What I won't do is ever, ever again get a dual points distributor. That pretty much sucked to tune. Stock points or HEI for me. Keep it Simple Stupid (KISS) is how I roll... Or maybe, it's the only way I CAN roll
Old 05-15-2017, 01:49 AM   #7
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: HEI Conversion
It is close alright -- mine is a GM HEI from a mid-Seventies Chevy. I had to remove the cap to drop the distributor in, but it has never hit the firewall.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 05-15-2017, 02:33 AM   #8
Toms67
Toms67's Avatar
Re: HEI Conversion
You could convert your points distributor to electronic. And you wouldn't have to worry about firewall clearance. Google this. PerTronix IgnitorŪ Solid-State Ignition Systems.
Toms67 is offline   Reply With Quote
Old 05-15-2017, 06:48 AM   #9
carryall
Re: HEI Conversion
I have did the conversion on both of my trucks. They make a small HEI distributor and that is what I when with it is great. I got both of my distributor
off of eBay.
1967 Chevy Truck
1969 Chevy Panel Truck work in progress
1971 GMC 1500 all orginal
1972 Chevy Suburban brought from orignal owner
1984 Dodge Rampage 45,000 original miles
1992 Dodge D150
1994 Buick Roadmaster (LT1 Engine)
2000 Chevy Stepside Z71
2008 Honda Element
carryall is offline   Reply With Quote
Old 05-15-2017, 07:12 AM   #10
sackracing
sackracing's Avatar
Re: HEI Conversion
A buddy of mine told me about the pertronix drop in, they did that on an early numbers matching Vette to keep the stock appearance.
66 SWB Fleet
Old 05-15-2017, 07:14 AM   #11
sackracing
sackracing's Avatar
Re: HEI Conversion
http://www.pertronix.com/prod/ig/ignitor/default.aspx
66 SWB Fleet
Old 05-15-2017, 08:02 AM   #12
panhead59
Re: HEI Conversion
That pertronix modual replaces the points and you get an adjustable rev limiter all for around $100. Used em for years, no problems.
panhead59 is offline   Reply With Quote
Old 05-15-2017, 08:56 AM   #13
sackracing
sackracing's Avatar
Re: HEI Conversion
https://www.holley.com/products/igni.../parts/59107CK
I'm a Holley dealer, but I don't see a drop in for the stock distributor. I could go this route.
66 SWB Fleet
Old 05-15-2017, 09:04 AM   #14
Sweeet67
Re: HEI Conversion
I just finished converting mr k10 to HEI. It is a tight fit but it's in without bending anything. It runs so much nicer now. I love it!
I also cut open the wire loom over to the firewall block and removed the inline resistor. I installed a whole new wire on to the factory connector. Not too big of a deal, just retaped it and put it back into the loom holder over the top of the firewall.
If you do a quick search, there is a pictorial thread of how to do it.
Sweeet67 is offline   Reply With Quote
Old 05-15-2017, 09:38 AM   #15
midniteblues
midniteblues's Avatar
Re: HEI Conversion
http://67-72chevytrucks.com/vboard/s...d.php?t=737738
I find this helpful when using a hei and a tach
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline   Reply With Quote
Old 05-15-2017, 09:45 AM   #16
sackracing
sackracing's Avatar
Re: HEI Conversion
Found this from Holley
https://www.holley.com/products/igni...s/parts/170072
66 SWB Fleet
Old 05-15-2017, 12:05 PM   #17
davepl
davepl's Avatar
Re: HEI Conversion
My "factory stock" appearing resto runs the Pertronix. As does my other high end resto! So I've had great luck with them.
In the truck the tach reads high at idle sometimes, I think it's the multispark feature of the module.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 05-15-2017, 12:08 PM   #18
sackracing
sackracing's Avatar
Re: HEI Conversion
That seems like best way to go, I need to pull the dist out and see if it's just plain worn out before I do that tho.
I'm trying to keep it looking like a late 60's custom.
66 SWB Fleet
Old 05-15-2017, 12:23 PM   #19
atog
Re: HEI Conversion
X2 definitely
atog is offline   Reply With Quote
Old 05-15-2017, 08:12 PM   #20
68 TT
Still plays with trucks
68 TT's Avatar
Re: HEI Conversion
With an HEI you want as much voltage to it as possible. The performance difference from using a fused terminal on the stock fuse box to a direct battery source that sees full alternator output voltage when running is hard to believe. Well worth the little bit of effort to set it up that way from the start.
Getting the power for the HEI from a full battery voltage source supplied 30-amp relay is the way I like to do my conversions. Use the stock resistor wire to actuate the relay. This way it is sure to get power during the start and run cycles of the ignition switch.
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been https://67-72chevytrucks.com/vboard/...d.php?t=484426
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
68 TT is offline   Reply With Quote
Old 05-16-2017, 08:30 PM   #21
sackracing
sackracing's Avatar
I'm going to a pre 68' show next weekend, I don't want to tear into it until after that. I'll update then.
Old 05-16-2017, 08:42 PM   #22
hjewell2
hjewell2's Avatar
Re: HEI Conversion
that's not a bad price for a HEI hi output
hjewell2 is offline   Reply With Quote
Old 05-16-2017, 08:50 PM   #23
sackracing
sackracing's Avatar
Not sure what my price on it is yet, I'll check tomorrow.
Old 05-16-2017, 11:10 PM   #24
RichardJ
Re: HEI Conversion
Seeing as you plan on driving it.
>>I'm struggling with getting my 283 / 2bbl / points ignition running smooth<<
Have you checked the dwell with a Dwell Meter?
To check for a worn out distributor, check dwell variation while checking mechanical advance and while checking vacuum advance.
Disconnect and plug vacuum line to distributor. With timing light and Dwell Meter connected, rev engine up/down. Timing should advance smoothly and return to base timing, consistently. During this test, dwell should remain steady and not change more than 1-2 degrees.
Connect hand vacuum pump to dist vacuum can. At idle, when vacuum is applied, timing should advance smoothly and return to base timing. During this test, dwell should remain steady and not change more than 1-2 degrees.
'67 GMC 2500, 292, 4spd, AC
RichardJ is online now   Reply With Quote
Old 05-17-2017, 06:32 AM   #25
Ken B
Re: HEI Conversion
I added a Pertonix distributor to my truck. Now all I have to do is look at the ignition key and it starts...
Ken B is offline   Reply With Quote
