Old 05-14-2017, 04:03 PM   #1
72LB
72LB's Avatar
Swapping frames info
I'm still kicking myself for this, shoulda seen it. I bought this truck a couple days ago sort of a barn find that barely ran(it's been fighting me since). You'll see in the pics the front is about two inches off. I limped it home and was told it drove straight and I never felt anything wrong.
My question is about legality of swapping frames. It's a 72, is the frame stamped somewhere?
72LB is offline   Reply With Quote
Old 05-14-2017, 07:06 PM   #2
terry b
terry b's Avatar
Re: Swapping frames info
Is the core support not bolted down? The gaps don't look bad for the front end being that far out.
terry b is offline   Reply With Quote
Old 05-14-2017, 07:46 PM   #3
72LB
72LB's Avatar
Yep it's bolted down. I pulled the drivers wheel and scraped away the crud on the frame. I found right behind the A arm there's a couple small wrinkles where someone attempted to straighten it in the past. Must have been hit in the drivers nose.
Old 05-14-2017, 08:29 PM   #4
kwmech
Find a real frame shop. Post up a pic of the wrinkle if you can
Old 05-14-2017, 08:39 PM   #5
72LB
72LB's Avatar
I can tomorrow. It's right where the frame turns up to the A arm. The pass side in that area is smooth, drivers has wrinkles at the bottom and the side is wavy.
Old 05-15-2017, 03:33 PM   #6
72LB
72LB's Avatar
Best pic I could get my camera isn't real good. The pass side in that same area is smooth. I also noticed the pass wheel well has been bent to so it could fit next to the frame.
Old 05-15-2017, 03:38 PM   #7
kwmech
Are you talking about the small flange wrinkle? If you are that's not a big deal, or will not cause the front to be out that much
Old 05-15-2017, 03:41 PM   #8
kwmech
Give us a pic of the engine compartment looking down on that area
Old 05-15-2017, 03:50 PM   #9
72LB
72LB's Avatar
Both sides.
Old 05-15-2017, 03:53 PM   #10
kwmech
I'm not seeing it, sure the body is square in its mounts
Old 05-15-2017, 03:55 PM   #11
demian5
demian5's Avatar
Shouldn't be a problem, bu the hassle and cost of installing a new frame, you may want to check and see how much to pull it on a frame machine.
The core support may have been loosened and the front end straightened out and then tightened back up...
But the bumper looks pretty damn spot on.
Wheel spacer on the drivers side and call it a day
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 05-15-2017, 03:56 PM   #12
kwmech
In front of the tire, measure from the frame rail to the fender.
Old 05-15-2017, 04:00 PM   #13
72LB
72LB's Avatar
Did that it's just under 2" off. Also measured the cab and it sits square with the exception of one of the mounts bent up on the drivers side.
Old 05-15-2017, 04:30 PM   #14
kwmech
I guess your next step is a frame and alignment shop. Anything out that far is going to need a frame rack
Old 05-15-2017, 04:55 PM   #15
72LB
72LB's Avatar
I just got a name of a good shop here in town, once I get it running again I'll take it to him.
That throws me also cause the bumper is square.
Old 05-15-2017, 05:08 PM   #16
terry b
terry b's Avatar
I really think a frame machine can pull that straight. I took a hit on the passenger side of my truck. Paid a local frame man 300.00. It's good as new.
Old 05-15-2017, 05:39 PM   #17
72LB
72LB's Avatar
Now that I have the name of a good shop I'm going to take it to them as soon as I get it running and more roadworthy.
Old 05-15-2017, 05:47 PM   #18
terry b
terry b's Avatar
Shur hope you can make it straight. Your frame look's mighty clean and rust free.
Old 05-15-2017, 05:54 PM   #19
72LB
72LB's Avatar
I hope so, frame wise it's decent for it's age.
Old 05-15-2017, 09:43 PM   #20
kwmech
Did you check their reviews?
Old 05-16-2017, 04:19 AM   #21
72LB
72LB's Avatar
Yes, highly recommended.
