Using a motor home tilt column question.
I found a motor home with a tilt column in it. Judging from the steering wheeL it's from about 73-75. It's in excellent condition and operates like new, and the price is very fair.
If I were to go back and get this, what does it take to mount it in a truck like ours? Is the length right? Will the linkage mate up? Will the backup switch need to be moved? Will it mount correctly under the hood? Any input will be appreciated. |
![]() Join Date: Jan 2010
Re: Using a motor home tilt column question.
The shaft should be good all you will have to do is move the neutral safety/ reverse light switch.
The Older Generation
This thread and the links posted in it should give you all of the information you need. http://67-72chevytrucks.com/vboard/s...d.php?t=133937 LockDoc
![]() Join Date: Oct 2011
To my understanding there were (3) different lengths available in these tilts (someone correct me if I'm wrong).
-The 'original' pickup truck tilts (fits in the 67-72's) -The 'Van' tilts, which did not fit without the shaft being changed out -The (big) 'Motorhome' tilts...which fit, but that depends on the type of Motorhome correct? ...if the motorhome has the 'Van' style front end with the camper back, is that not the tilt as the typical 'Van' tilts? All Good Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL 1966 Chevy 1/2 ton (Florida- Red/white) 1972 Chevy 1/2 ton (California- Blue/white) 2005 Chevy Silverado HD2500/Duramax 2000 Dodge Ram 1500 |
Thanks to all for the info. It looks like I'll be making a road trip in the near future.
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
In theses pics the column with the red thing on it is from a 1973 motorhome and its a tad shorter than the 67-72 column. The slot has been cut to move the neutral saferty switch lower on it. The other is from a 67-72 but not exactly sure which model it came out of except the shifter handle is shorter thatn the original on my non-tilt column 72.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
My main concern was the length, and then the angle of the shift linkage hookup.
I figured on having to move the back up switch, but that's easy. AlreadyGone, thanks for the pictures, they speak a thousand words ![]() |
![]() Join Date: May 2010
Here's a picture of, from top to bottom, a motorhome tilt, a truck tilt and a van tilt. From what I've read, the transmission linkage will work fine with the motorhome attachment arm. Therefore, as mentioned above, the neutral safety switch should be the only obstacle.
So, get that column before someone else does! |
I'm on it!
