Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 05-31-2017, 11:35 PM   #1
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
What do you recommend for an air drill?
Beginner here. I've never owned one & don't really know what to look for. My compressor is 13 ga. 5.5 @ 90 PSI. At any rate, I'm hoping to accomplish:
1. Low speed for buffing out our original plastic steering wheels, with white rouge and a buffer similar this http://www.eastwood.com/canton-flannel-buff-wheel.html
2. Long story not short enough, I'm removing the useless aux. tank from my driver. Two of 10 #10 screws wouldn't budge off the cover attached to the bed, so I had to cut off the heads. Either the moderate electric drill won't cut it or it's the Irwin cobalt bits I just picked up, and I'm guessing it's the drill. Anyway, I can't seem to drill out what's left of the screws. Should be easier. High speed better?
3. I don't know, maybe some type of pads on arbors to clean-up up the frame prior to paint. That and all around DIY use.
Thank you.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C.
I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
