View Poll Results: Fix or New?
Remove and weld/strengthen existing then reinstall. 0 0%
F it! Buy new to replace older cracked RECIEVER 0 0%
Voters: 0. You may not vote on this poll
Old 07-04-2017, 04:34 AM   #1
SACRAMENTO 71
SACRAMENTO 71's Avatar
Concerning Surprise Find 00 K3500 drw
Evening Everyone, Happy 4th!!
Putting 2017 Denali Dually wheels on my 00 k3500, so I decided since the truck just turned 110,000k I would replace upper and lower bail joints, all bushings, and shocks.
While under rear of truck while replacing the rear shocks I came across a 3/8 inch crack on the TOW RECEIVER!!! WTF!! Never expected to see one, let alone two, each one at the same spot, one right side, other left side.
I'm still shocked, how the hell did that happen. I just towed 16k 70 miles each way in the foothills. WOW!
Anybody ever experienced this type of failure on factory trucks?
Thanks for your help and inspect your equipment!!! Nick
68 C10 SWB W/ 72 FRONT CLIP 343SB TH400
64 C10 SWB 406SB TH400
74 SUBURBAN 454BB TH400
78 K10 SWB 350 TH350 6" ON 35" BFG MUD
71 K5 350 W/ TBI 700R4 6" ON 38" BFG MUD
00 K3500 DRW BIG BLOCK "DRINKING PRBLM"
SACRAMENTO 71 is offline   Reply With Quote
Old 07-04-2017, 04:42 AM   #2
SACRAMENTO 71
Re: Concerning Surprise Find 00 K3500 drw
Couple pics!!
Old 07-04-2017, 04:43 AM   #3
SACRAMENTO 71
#2
Old 07-04-2017, 09:26 PM   #4
95 S_Trucker
95 S_Trucker's Avatar
If that is a gmt400 truck(88-98 style), the hitch is only rated for 10,000 pounds. That could contribute to the cracked hitch. The frame is supposed to be flat at the rear. The pics make it look bent.
It looks like overloading to me.
Quality hitches are cheap. I personally like curt manufacturing. But the frame will need straightened first.
95 S_Trucker is offline   Reply With Quote
Old 07-05-2017, 09:41 AM   #5
d4xycrq
16,000 pounds!? You mean combined weight? (truck & trailer)
If you mean just the trailer and load, you need a goose neck. But that's none of my business.
Meanwhile, I'd have a welder weld up that existing hitch. A good welder can make that puppy bulletproof.
Ray
d4xycrq is offline   Reply With Quote
Old 07-07-2017, 10:15 AM   #6
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Key word there is "good" welder.
I'd just go buy a new hitch and not even mess with it.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 07-09-2017, 09:41 AM   #7
Flying Hamster
Flying Hamster's Avatar
That's not a crack, that is a break. That is a part failure.
Get a new hitch with better load capacity, and check everything else in your setup.
Consider the tongue load and the terrain you tow over.
Best guess from here is maxed tongue load and bumpy roads/offroad use.
2006 Sierra RCSB V6 5 Speed RWD.
Flying Hamster is offline   Reply With Quote
Old 07-10-2017, 08:58 AM   #8
95 S_Trucker
It was definitely over loaded.
The frame will need straightened before putting a new hitch on.
Some pics the op posted:
http://67-72chevytrucks.com/vboard/s...&postcount=923
http://67-72chevytrucks.com/vboard/s...&postcount=924
I don't want you take this the wrong way, but towing that much weight is very unsafe. It's on thing if you are towing off road or down a farm lane, but you have to remember that you aren't the only thing on the road. Other drivers are at risk if something happens to your overloaded truck.
These trucks are rated at 10,000 for the rear hitch receiver, and 12,500 for a fifth wheel. You need a bigger truck(medium duty) with a fifth wheel hitch if you arte going to continue towing that much.
Old 07-16-2017, 07:35 AM   #9
72MARIO
72MARIO's Avatar
Isn't the bolt pattern diffirent on 2007 up trucks? Not buy much they fit but the lugs don't center properly.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 07-16-2017, 08:25 PM   #10
95 S_Trucker
We are in the 99-06 section. The truck in question is a 99( but it's the 88-98 style truck)
Old 07-17-2017, 07:58 AM   #11
95 S_Trucker
I think I understand your post now. Your talking about wheels, not about the hitch?
The lug pattern changed in 2011 for 8 lug trucks. Adapters are needed.
