Old 07-26-2017, 12:52 PM   #1
cgster
Engine Temperature Gauge
My temperature gauge isn't working, not sure if its the wiring or the gauge itself. Anyway, instead of replacing my current gauge, is there a cheap under dash temperature gauge I can buy to test out if the gauge is the issue before I pull my dash bezel off and replace that temp gauge?
cgster is offline   Reply With Quote
Old 07-26-2017, 02:05 PM   #2
briank
Re: Engine Temperature Gauge
I just went through this...what year truck, engine size and year of engine? From what Ive read , they say its rarw for the dash gauge to go bad. Check your sending wire 1st
briank is offline   Reply With Quote
Old 07-26-2017, 02:10 PM   #3
cgster
It's a 68 C10 truck, 383 stroker engine. Not sure of year on engine.
Old 07-26-2017, 02:16 PM   #4
VetteVet
Msgt USAF Ret
VetteVet's Avatar
There is an easy test to check the gauge.
Take the sending unit wire off and ground it against the block and the gauge should go full hot with the key on. If it doesn't move then the gauge isn't getting a ground from the wire or it isn't getting voltage from the gauge cluster.
It could also be a bad gauge.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 07-26-2017, 02:17 PM   #5
briank
Reason I ask about year of engine is because newer sbc use a 3/8" temp send unit...older uses 1/2". The 3/8 wont read right with factory gauge, but usually read hot. Yours does not work at all so Id check your wire then go from there. Others should chime in.
Old 07-26-2017, 02:33 PM   #6
cgster
VetteVet, When you say "ground it", do you mean just disconnect sending wire and touch to the block? Sorry if thats a stupid question but I dont know jack about electrical issues.
Old 07-26-2017, 03:30 PM   #7
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Yes, you can just touch it to a bare spot on the block or run a jumper to the negative battery terminal. It should react immediately.
VetteVet
