33x13.5r15 Tires
I was wondering if anyone has ran 33x13.5 tires on their rig, I'm going to do either a 2" or 4" lift, and taking the wheel tire combos I can run into consideration.
Posted via Mobile Device |
![]() Join Date: Jan 2000
Re: 33x13.5r15 Tires
I run 33x12.50x15 without any lift.
70 Jimmy 4x4 71 GMC 2500 Too bad stupidity isn't painful |
![]() Join Date: Jun 2014
stick with a 4" BS on an 8" wheel and you shouldnt have any rubbing issues, as long as your suspension isnt toast.
1970 1/2 ton 4x4 4spd Suburban 1972 K10 350/700R/205/ Sniper EFI Daily Driver Sold 1971 K5 on 35s Traded 1972 K5 3/4 ton PROJECT Sold |
![]() Join Date: Jan 2001
Same here, no rubbing. One consideration is going to be wheel width. I have GM truck rally wheels - they're 8 inches wide. Most tire manufacturers recommend going no more than 12.5 tire width on an 8 inch rim.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
![]() Join Date: Mar 2009
I had 33x12.50 tires on my 70 blazer and they rubbed on full lock at stock height. I installed a 2 inch lift and no problems since. Here is a pic with the lift. I think my sig photo is 33s without a lift.
Jeremy 1969 Blazer 4x4 original cst 1971 Blazer partial 2wd convert 1972 Blazer 4x4 original cst 1970 Blazer 4x4 w/ 2 1/2in lift and 33in tires w/4 wheel camper 1970 4x4 suburban w/ 6in lift and 35in tires 1968 Corvette convertible 1970 Malibu convertible 1959 Brookwood wagon 1972 International Scout ii |
![]() Join Date: Mar 2014
From personal experience, if you are doing any freeway driving in your blazer don't go with a 13.5 wide tire. It will pull you all over the road. Stick with a 12.5 or better yet a 10.5. But for a simple no frills trail rig 13.5 on an 8 or 10 inch wide wheel will work just fine.
'72 Blazer DD 33's '78 F-250 w/ 1 tons and 37s '41 olds 98 on bags 2011 vw jetta (wifes) |
33 X 12 1/2 on mine with stock lift and no rubbing issues at all. I can cruise 75 MPH with no handling issues. 13 1/2 might be pushing it !
I ran 33 14.5 Mickey Thompsons on my Jimmy with an 8" rim. They rubbed on the leaf springs when turning and they rubbed on the inside of the tub in the rear of the tub as well. 10" rim would probably fix that.
I think 4" lift is too much with 33" tire so I'd go two. If you go to 4 then 35's. Have a project Jimmy for my teenager that we bought 4" springs for because the lift was on sale at almost half of what the 2 1/2" was. So I guess that means 35's!
