Old 09-09-2017, 12:26 AM   #1
randy500
WTB: TH 400 transfer case adapter to NP205
Need the figure 8 style on the transfer case...anybody got one to sell?
randy500 is offline   Reply With Quote
Old 09-09-2017, 08:28 AM   #2
John H.
John H.'s Avatar
Re: WTB: TH 400 transfer case adapter to NP205
I have a nice one.
John H. is offline   Reply With Quote
Old 09-09-2017, 09:28 AM   #3
randy500
Originally Posted by John H. View Post
I have a nice one.
You should just give me an inventory of everything you have so I don't have to post ads...
add that to the other stuff, do you have the 205 that mates to it or the input gear also?
Old 09-09-2017, 09:31 AM   #4
John H.
John H.'s Avatar
I posted to quick! I just have the 350 auto adapter, sorry!!
Old 09-09-2017, 09:38 AM   #5
randy500
Well I may need that anyway, might use th350 or 700r4 until I decide to spend the big bucks on the 400 or 4l80e
Old 09-09-2017, 08:34 PM   #6
KSCHEVYUP
KSCHEVYUP's Avatar
I have a TH400 adapter and a bare NP205 case with the large 90MM input bearing bore for the TH400 that I have listed on local Craigslist for $350 for the pair. Shipping charges to Washington might be a deal breaker though?
1972 C30 Cheyenne Super
1971 C10 (Parts truck)
KSCHEVYUP is offline   Reply With Quote
Old 09-09-2017, 08:39 PM   #7
randy500
I guess that's what those go for...hmmm
Can you measure the transfer case, there is a large flat rate usps box for game boards that might work.
I can check shipping if you give me dimensions and weight of both pieces in one box.
Do you have the 32 spline input gear?
Old 09-09-2017, 09:01 PM   #8
KSCHEVYUP
KSCHEVYUP's Avatar
I don't have the 32 spline input gear; but I will get the measurements and dimensions.
Old 09-09-2017, 09:12 PM   #9
randy500
Ok, thanks
Old 09-09-2017, 09:15 PM   #10
KSCHEVYUP
KSCHEVYUP's Avatar
TH400/NP205 adapter weighs 19#
Measures 11" high X 7" wide X 4-1/2" thick.
NP205 empty case weighs 46#
Measures 19-1/4" wide X 11" high X 6-1/4" width.
Ron
Old 09-09-2017, 10:18 PM   #11
CG
BlahBlahBlah
Just a question not trying to jack ... So if you want to put a turbo 400 in place of a 350 you have to put in a different 205 because the case is different?
Old 09-09-2017, 10:21 PM   #12
randy500
The 205 is the same, except the input shaft needs to be 32 spline which requires a larger bearing and the case needs to be bored out to accommodate the larger bearing.
Or buy a complete 205 that came from 85 or newer or was originally behind a th400
Old 09-09-2017, 10:24 PM   #13
randy500
The good thing on the th400 though is you can use a short shaft 2wd trans instead of the very short 4wd th400 output shaft
Old 09-09-2017, 10:27 PM   #14
randy500
shipping is about $60 on the main case and I think the adapter fits a med flat rate for $16.
I would need to be at $350 including shipping because the adapter new is $252 and I figure boring my case is about $100
Old 09-10-2017, 08:58 PM   #15
randy500
Parts found, bought a k20 today with th400 and np205
