1961 crewcab
85 to a 77?
will a 85 cab and front sheet metal bolt onto a 77 frame? I have a super rotted 77 with great running gear, set up as a plow truck, and I have a 85 that has a decent cab and front clip, wondering if all the mounts line up if it wouldn't be too hard of a swap?
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
![]() ![]() Join Date: Jan 2015
Re: 85 to a 77?
Should swap right onto the 77 frame with no problems just use the 77 cab and radiator core support rubber mounting cushions as they are different on a 85
1961 crewcab
Re: 85 to a 77?
thanks! that is what I needed to know!
