Would anyone know the the correct length of a swb 72c10 driveshaft, thanks for any help.
Re: swb driveshaft length
Not off the top of my head, but I want to say 55.5" ,that is for my sbc in the front V-8 POSISTION with a 4l60 trans . What transmission you have determines what length you need JFYI
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327/4L60 |
Thanks for the reply, I have a Saginaw 3 speed. The truck is a long wheel base at present,thats why I'm seeking this info. Thanks again
I took 11 1/2" out of my two piece driveshaft. It was easier than building a one piece and alot cheaper since I did it myself. If you retain the 3 spd then you are as well off waiting til you get the truck shortened and measure. That will insure you wont have to build one on a guess. If you go with a mainstream auto transmission, then you may get lucky and find one in an old junkyard.
:My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=807535 1972 K10 swb/1968 Camaro 350/4spd 1955 210 2 dr sedan/1998 RCSB Z71/1977 Jeep CJ5 |
Thanks for the reply, I'm kind of leaning in the direction you suggested. I think it would be better to get rid of the carrier bearing if I could.
Before and After
I stopped by my local drive line shop the other day to ask if it is better to have one piece or two. with all the experience they had, they recommended a single piece shaft, as long as you have room for the larger diameter.
They had given me the directions to measure for my application. - with the yolk installed into the trans, pull it out 3/4" - 1". - measure from the center of where the U-Joint will be on the Yolk to the center of where the center of the U-Joint on the Pinion will be. This is to be done at ride height if you have changed yours from stock. - Bring them the info and pick up the new shaft the next day or two. ** They will need to know if you have a powerful Engine that they need to beef up the shaft for you as well.
Not Grandpa's C-20 anymore... 383 Stroker 425HP, 485Ft/Lbs Lowered 3.5" Front / 5" Rear 66,000 miles. Alberta, CANADA |
Thanks for the info, I guess the bigger diameter will work because they came from the factory with a one piece. thanks again
#8 | |
A shortbed with the 3 spd saginaw drive shaft is 55 inches in lenth from center of U joint to center of Ujoint A Short bed with a TH 350 or a 200 4r is 58.5 inches in lenth center of U joint to center of U Joint . I can get you the lenth for a TH400 also I just would need to get under my 69 let me know if you need that But I would still wait till you are ready and take the ruler to it your self... |
Thanks for the reply, no need on my part for the 400 measurement,I'm sure others might want to know. Thanks again for the good and helpful information.
