10-26-2017, 10:51 PM | #1 |
What else do i need to make this horn work on 88-94 steering wheel?
I just picked up this steering wheel from a local seller.The horn button has 2 terminals on it.What and how does this work on a 87 C10?
10-27-2017, 08:29 AM | #2 |
Re: What else do i need to make this horn work on 88-94 steering wheel?
Heres a break down from GM parts........looks like you need the one contact (the lead wire) for the horn.....
https://www.wholesalegmpartsonline.c...wd=&origin=pla ......I would think these would be Dorman replacement parts.......DORMAN horn wire lead 49319.......I just reassembled my steering 2 weeks ago I had to go in and lock tight those 4 loose bolts in below the tilt assembly....I got the turn signal cancel cam and twist lock contact from Oreillys in Meridianville from the Dorman help aisle.......this is the sight I went to help guide me on reassembly of my 87 GMC tilt steering column........ http://www.crankshaftcoalition.com/w...ck_Rebuild.pdf
http://i204.photobucket.com/albums/b...baae5d9a7e.jpg Last edited by RUN GMC; 10-27-2017 at 09:02 AM. |
10-27-2017, 11:32 AM | #3 |
Just need contact wire like RUN GMC said.
https://www.summitracing.com/parts/i...SABEgJw2PD_BwE |
10-27-2017, 05:20 PM | #4 |
Irish nailed it.........its $3.04 + $6.95 shipping = $9.99 from Summit
its $5.09 + $2.99 shipping = $8.08 from Rockauto in our area Summit would be quicker but Rockauto is cheaper(lol big deal)........hoped we helped you out some........ http://www.rockauto.com/en/parts/dor...connector,2588
http://i204.photobucket.com/albums/b...baae5d9a7e.jpg |
10-27-2017, 09:04 PM | #5 |
Might check the pic in the link in post 4 and check the help section for 49319 at the local parts store.
10-28-2017, 12:00 PM | #6 |
I put the link up for just for photo reference.
Just grab one from junkyard if you have one close by. A ton of GMs used that same wire. |
