Power steering pressure hose ???
Hello everyone. I have a question that I have not found an answer on. I have a 67 C10 that I am building and I installed a 68+ power steering gear box and I have a serpentine belt system from GMPP that is based on 90-95 models. The gearbox hose is SAE 5/8 male inverted flare and the pump is metric 18mm male o-ring. I got one of those adapters and it always leaks and I have not even started the truck yet. I did read you could swap outlet fittings on the pump but I do not have an old pump and did not see a fitting available online. I am about to buy a pressure hose for each system and take it to a place and have them spice the two good ends together to make one hose. I already stopped by my local NAPA and while they do hydraulic hoses they will not touch a steering hose. Anyone else tackle this issue with good results?
Re: Power steering pressure hose ???
You just need the fitting that screws into the back of the pump. If you have a junkyard nearby it should be easy to find one. Ill look for an online source for a new one though. Pretty sure most GM Full size cars and trucks used the same flare fitting untill 1979-80 or so. OR you can use a newer truck steering gear that has the metric fittings, and you could possibly get a better ratio or variable ratio gear box depending on what gear you have now.
My thinking too, have done it quite a few builds. $ saver.
Mudman.
1987 Green n Green machine. 5.0 4spd std. 7" lift w 35's. |
Great pics Chevy4Life. I will take make a new attempt and see what I can come up with. Thank you.
https://www.ebay.com/itm/1964-79-GM-...lXGPKd&vxp=mtr
I think this is it but you should contact inlinetube to be sure. I'd still try to find a used one because $28 is steep to me. |
Thank you again for the information and example of what I am after. While pricy it is cheaper than buying two hoses and paying a shop to make one out of it and it is cheaper than my time and gas to go junk yarding an hour and a half away. I will certainly check it out and consider it.
#7 | |
#8 | |
'59 Apache - 383" SBC/TH-350 '68 GMC - BBC/TH400 |
I did order the fitting mentioned above. I will try to report back with my findings once it is received and installed.
