Old 11-27-2017, 10:06 AM   #1
67see10
67see10's Avatar
Eaton Posi vs Eaton Detroit TruTrac
I know that this debate has been discussed time and time again. It appears that most people recommend the TruTrac over the Posi unit simply because of the Posi unit has a clutch that can potentially wear out over the years.
I haven't seen any comments as to a clutch actually wearing out and was trying to get a general idea on how long they actually last. I would imagine that the way a person drive will have a major impact on the lifespan of the clutch.
I'm trying to determine which unit to put in my 67 c10 project. I plan on running a 5.3 LS with a 4l60e transmission. The gear ratio I plan on using Richmond 3.73 Ring and Pinon in the rear end.
67see10 is offline   Reply With Quote
Old 11-27-2017, 11:45 AM   #2
Bigdav160
Bigdav160's Avatar
Re: Eaton Posi vs Eaton Detroit TruTrac
Trutrac works great as long as both tires have some traction. If one wheel is in the air or has zero traction it works like an open differential.
Clutch wear usually is caused by mismatched tire diameters or constantly turning circles under power otherwise they can work forever.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 11-27-2017, 09:26 PM   #3
Mike C
Mike C's Avatar
The clutch limited slip is also traction limited if one tire is off the ground. Either can be "activated" a little with the use of the brake pedal.
Figure 50-100,000 miles before noticeable change in performance on the clutch type. The TruTrac is very unobtrusive in use however. We are building a Jimmy for my son and I think TruTrac is on the short list unless I score a GM posi cheap somewhere.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 11-29-2017, 01:17 AM   #4
Z10
Z10's Avatar
I have a PowerTrax installed in my 72 and in my 69 Camaro. Love it.
Watch this:
https://www.youtube.com/watch?v=8k-LmnS3ED0
1969 RS/SS Z10 Camaro Pace coupe
1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218
1979 Mazda RX7
1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Z10 is offline   Reply With Quote
