![]() Join Date: Feb 2013
Sound deadener in the cab corners...?
Removed the in-cab tank and now swapping out the carpet. Looking for advice on what to do with the inside corners. Should I use sound deadener mat in this area or are there better options? Also wondering if there is any reason not to add sound deadener to the back wall of the cab. I have a piece carpet that will cover the back wall.
Would also like to see ways to make the space behind the seats usable for storage, although I don't know what I would need to put behind the seats. Maybe a set of jumper cables, fire extinguisher, small toolbox, etc. |
![]() Join Date: Jan 2002
Re: Sound deadener in the cab corners...?
maybe if the cab corners are non-rusty ?? id spray w/ bed liner or undercoat ?
![]() Join Date: Aug 2004
I would not stuff sound deadened down there myself. I would put some on the back wall tho. Good luck!
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
It's Better With Nitro
I used sound dampening mat in the corners. I did treat any rust in the area before hand.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes Last edited by vin63; 01-24-2018 at 11:11 AM. Reason: typo |
