Old 01-28-2018, 03:30 PM   #1
72farmer
Will a rearend out of a 90 Surburban fit a 87 truck?Was Gov lock any better in 90?
I just bought a complete rearend out of a 90 model Surburan.I pulled the back cover off and it is a 3:73 ratio with a Gov-Lock locking diff.It also matches the code in the glovebox.
I read somewhere the axle's were upgraded to more splines and the Gov-Lock was better than the older ones.I am planning to put it in my 87 C10.Will it bolt right in and will the ujoint yoke be the same?
72farmer is offline   Reply With Quote
Old 01-28-2018, 04:58 PM   #2
mongocanfly
mongocanfly's Avatar
Re: Will a rearend out of a 90 Surburban fit a 87 truck?Was Gov lock any better in 90
....I've never heard of one being upgraded...
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 01-28-2018, 06:13 PM   #3
Matt Man
Matt Man's Avatar
The rear end should fit just fine. However, as far as the axle being upgraded to larger axle shafts I think that only applied to the front 10 bolt starting in (89?) The Gov-Lock is ok in a mostly stock application but it is 28 years old more and likely. So I would inspect it and make sure it doesn't grenade as soon as you swap it in.
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11
1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020
67 GMC Stepside Straight six/3 on the tree "The Peach"
2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver
K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934
The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903
Matt Man is offline   Reply With Quote
