Old 01-27-2018, 05:39 PM   #1
Curtb1971
Curtb1971's Avatar
Restored Tach/Vac gauge cluster
Up for grabs is a restored V8 tachometer/vacuum instrument cluster using all oem gauges(70-72 speedometer, 60lbs oil gauge). The bezel and circuit board is new aftermarket. The lens was a older aftermarket replacement and actually matches the gauge paint very well compared to some. The tach has a slight fade on the black but mint green pattern is great. Im not going to say its 100% perfect but for being old oem truck parts it turned out pretty nice. Work included
-Bead blast and paint tins
-Polish lens
-Tediously clean gauge faces and repaint needles
-Oil/grease moving parts
-Odometer set to "zero" miles
-Assembled with reconditioned oem and new stainless hardware
-Test gauges for proper function.
Included- is the vacuum line fitting for vacation gauge and some nice wiper/light switch bezels for a clean install
$650(SOLD) shipped/insured conus in foam lined box
Note: Can swap the 60lbs oil gauge for an 80lbs for an additional $25
1971 LSX "Bonnie" build thread
http://67-72chevytrucks.com/vboard/s....php?p=8026381
paypal is curtbarton1971@yahoo.com
Curtb1971 is offline   Reply With Quote
