![]() Join Date: Mar 2015
Door Panel Clip "Grommet Ring"??
Reassembling my door and should be putting the door panel back on tomorrow. A few of the door panel plastic clips had a rubber washer/grommet/o-ring on the base of the shaft (see pic). Are they necessary or useful? Did a search and came up with nada. As always, thanks for any input!
#2 | |
The Older Generation
Re: Door Panel Clip "Grommet Ring"??
I've never seen them on one of our trucks before. I wonder if someone put them on to take up the slack on the panel clips..... You shouldn't need them if you have new clips. LockDoc
![]() Join Date: Feb 2010
Location: Falls City, Nebraska "100 Miles From Nowhere"
I haven't run across them on neither of my 72's. But somebody did show them to be a factory installed item on a thread here a week or so ago. I think they were used as a dust or moisture seal. One of those parts like the foam dust seal that's never in place under the horn button on OEM steering wheels...
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" ![]() "Be American, Buy American" ![]() |
To me it looks like someone had some extra valve stem seals and didnt know what to do with them!
'71 Cheyenne Super LWB - Second Owner in 39 Years! '70 CST/10 SWB - Soon to be Daughter's truck when finished |
So, sounds like certainly not necessary. Kind of like the fender to door seal on Cheyennes? Probably just go without them and add a moisture barrier between the panel and door. Thanks for the feedback!
