Old 03-25-2018, 11:09 PM   #1
Matt Man
Matt Man's Avatar
Need transmission help
So I finally got around to installing my deep transmission pan with a drain bolt and I was going to service the trans anyway since I have never done it in the 3 years I have had it. It started to shift more and more firm so I thought I would put the new pan on and have some fresh fluid mixed with the old. I know what COULD happen if you service a old transmission. Anyway, I got the pan off and the fluid was way worse than I thought it was was very dark brown in color and had metal shavings in the pan.
This is not the picture I took, but it looked very similar to this inside:
http://67-72chevytrucks.com/vboard/a...1&d=1522033445
So I put the new pan on and the thing leaks through the casting through a pinhole GREAT. So I ended up pulling the new cover off and just reusing the old one. The shifts are more smooth now but the converter is constantly locking and unlocking which also makes the truck jerk violently. Also, the truck sometimes will die when I come to a stop. So I guess the question is am I looking at a rebuild in the near future? The transmission is a Turbo 350c on my 81 k10.
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11
1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020
67 GMC Stepside Straight six/3 on the tree "The Peach"
2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver
K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934
The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903
Matt Man is offline   Reply With Quote
Old 03-26-2018, 12:01 AM   #2
Irish1941
Irish1941's Avatar
Re: Need transmission help
Locking and unlocking? With TH350? That's a 700R4 thing.
TH350 is on all the times. The convertor is not locking and unlocking. I'm thinking that's bad clutch you're feeling. Slip-grab-slip-grab
Like electrical, trans troubles are hard to diagnose online.
Im leaning towards the convertor has cashed out. More than likey pump is going out too thanks to convertor chunks.
If your seeing metal in the pan and with stalling out, convertor is finished. There is no clutch left in convertor so its direct to engine which causes the stalling. Convertor needs to slip at a stop or engine stops.
Im no trans rebuild expert but been down that road more than once.
Best GM trans guy. Hands down
http://www.phoenixtrans.com
Irish1941 is offline   Reply With Quote
Old 03-26-2018, 12:43 AM   #3
Willowrun
Willowrun's Avatar
TH350C has a locking TC. You could always pull the electrical plug out of the trans if you don't want it to lock.
Old 03-26-2018, 12:59 AM   #4
kwmech
With the amount of debris in the pan, I'd say you were ready for a rebuild anyways. You can increase the clutches in the drums and a mild shift kit and be good to go.
Old 03-26-2018, 01:18 AM   #5
Irish1941
Irish1941's Avatar
You are correct.
I forgot about the 350C trans...as did most everybody else.
