Old 02-05-2018, 11:12 PM   #1
ZEKE68
ZEKE68's Avatar
LMC 2 1/4" dual exhaust system ?
Anyone use the LMC dual exhaust system with 2 1/4" pies on their truck? Thinking of ordering it but was wondering what the fitment was like. Does it run below the frame until it gets past the rear trailing arm cross member ? Would appreciate any info.
1968 SWB Step Side, Big Block, 4L80E , Running!
ZEKE68 is offline   Reply With Quote
Old 02-05-2018, 11:25 PM   #2
Toms67
Toms67's Avatar
Re: LMC 2 1/4" dual exhaust system ?
I bought the kit for my truck. I bought the ones that to go straight out the back. They had to send me two new pipes from the muffler of the back. The first ones they sent were one piece. They were bent wrong. I had to call heartthrob. I told them I bought them from LMC. And they sent me new pipes that are two peice. They fit fine.
Toms67 is offline   Reply With Quote
Old 02-05-2018, 11:33 PM   #3
ZEKE68
ZEKE68's Avatar
I was going to do the stock behind the tire exit. Those look good. Thanks very much for posting.
Old 02-05-2018, 11:39 PM   #4
B. W.
B. W.'s Avatar
The kits are from Heartthrob Exhaust. Can't help you with fitment on a 2wd but I installed one on a 4wd a couple of years ago. It was the best fitting kit I've ever used, great price too.
B. W. is offline   Reply With Quote
Old 02-06-2018, 09:47 AM   #5
TCCGRIZ
I bought a dual set for my 70 k10 worked great , bought a single for my 68 c10 with a 292 ,also worked great .no fitment issues on either one
TCCGRIZ is offline   Reply With Quote
Old 02-06-2018, 10:29 AM   #6
ZEKE68
ZEKE68's Avatar
Are those the stock muffler option? How did they sound?
Old 02-06-2018, 10:40 AM   #7
Larry Weaver
Put Heartthrob on my 68 C20 last spring. Fit ok but touches starter and tail pipe needed a dimple for the arm at rear end,(coil spring truck) Have glasspacks, little loud but it spoda be !!
Larry Weaver is offline   Reply With Quote
Old 02-06-2018, 11:16 AM   #8
Grumpy old man
Grumpy old man's Avatar
Go to your local muffler shop and have them install a welded system and be done with it in a few hours . Unless you just like the UPS truck ?
Old 02-06-2018, 11:29 PM   #9
Cheaper is nice...if you get a good product. But I'm a custom exhaust kinda guy. To me it is worth any extra to choose how your pipes route, exit, diameter, as well as know the quality of the pipe used. I don't like any part of my exhaust to run lower than my frame. Got to go custom for that.
Old 02-06-2018, 11:38 PM   #10
TCCGRIZ
The duals ,I had the stock option . Nice and quiet. Had the single with the other sounds good.
My 4wd with the duals the exhaust is tucked up nice inside the frame rails . Only hiccup was clearing where linkage to the tranny hookup to the tranny (automatic btw) paid the muffler shop 40 bucks to fix it
Old 02-07-2018, 08:22 AM   #11
Different story w/coil rear. I guess that is what I was thinking.
Old 02-07-2018, 08:51 AM   #12
bbrriiaann1973
Not interested in being quiet
Brian Ritter
bbrriiaann1973 is offline   Reply With Quote
Old 02-17-2018, 12:26 PM   #13
ZEKE68
ZEKE68's Avatar
Toms67, Thanks for the pictures. They helped a lot. At first I thought they mismarked the pipes that go over the swing arms for the wrong side but they worked. First thought that you put the mufflers vertical by preference but that is how they have to go isn't it. Tilted mine just a little. I have the rear from the cab back installed and now have to figure out how to connect them to my big block manifolds.
Old 02-17-2018, 02:28 PM   #14
Toms67
Toms67's Avatar
Yes they were marked wrong. But you can pretty much tell right away. The first set of tail pipes i received. Where one piece. They replaced them with a two piece set. A lot better fitment. Yes I had to install the mufflers vertical. I am going straight out the back with mine. On the big block I am not sure what you have to do for fitment. Unless they make a special donut gasket that will adapt? Good luck.
Old 02-17-2018, 04:58 PM   #15
Husker
Husker's Avatar
Did My 6 cylinder short box a few months ago. Fit looks like what I replaced. Fit is Good, I think. Sounds Good to. Old exhaust was rotted and I believe it was Factory.
Did a dual Kit on My 4x4 a few years ago and it fit Good also. Reason I chose the LMC/HeartThrob is because they are Mandrel bent, don't lose pipe size.
Ron
Member #111
68 C-10 Daily Driver
70 4x4 Project
76 Jeep CJ-5
Help Support the Board:
http://67-72chevytrucks.com/vboard/payments.php
He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors.
Thomas Jefferson
Husker is online now   Reply With Quote
Old 02-17-2018, 05:24 PM   #16
54blackhornet
54blackhornet's Avatar
Can anyone explain what to do if you want dual exhaust but have leaf springs in back....
71 C-20
07 Magnum RT AWD
54blackhornet is offline   Reply With Quote
