Measuring for a new driveshaft - does this make sense?
Just finished a lwb to swb conversion and I'm looking to replace my two piece driveshaft with a one piece. I need a measurement for the driveline shop.
A couple questions for the drive shaft pros here: To get the best measurement, I was hoping to measure from u-joint to u-joint. I pulled the slip yolk off the old shaft and pressed it all the way into the transmission. Then I slid a rigid piece of cardboard through the middle of front yolk: ![]() Moving back to the rear, I made a measurement from the base where the u-joint rides (bottom of the laser measure): ![]() Three measurements from three spots on the cardboard were all the same; about 60 inches: ![]() Does this approach makes sense? Is there a better way to measure what I need? Second question, how does this measurement compare to those running a 1-piece drive shaft? This is a 1970 C-10 w/ a 350 and 350 tranny. Also, what diameter shaft should I expect?
1970 C-10 "Old Yeller" |
Re: Measuring for a new driveshaft - does this make sense?
You need to pull the slip yoke out of the tranny about 1 inch and then measure from Center to Center on the u-joints.
You should also have your pinion angle set correctly to get an accurate measurement. |
Before and After
agreed with the 1" slip yolk measurement. my driveshaft place told me 3/4", but what is 1/4" between friends?
Not Grandpa's C-20 anymore... 383 Stroker 425HP, 485Ft/Lbs Lowered 3.5" Front / 5" Rear 66,000 miles. Alberta, CANADA |
My shop said pull the yoke out 3/4"
If I remember correctly it was around 58 3/4", but I have a TH400 trans in mine.
Project Engine Stand 1972 SWB conversion: http://67-72chevytrucks.com/vboard/s...d.php?t=673914 1970 Nova: http://67-72chevytrucks.com/vboard/s...d.php?t=708161 |
Just ask the shop that is going to shorten your driveshaft and use their directions. Don't try to second guess.
1970 GMC 2500 700R Trans, RideTech 4 link rear suspension, air bagged on all four corners, factory upper/lower A-Arms, 2 inch drop spindles. 350 SBC 300hp Weiand Supercharger FiTech 30004 EFI |
2nd
Just trying to figure this out... 1970 SWB Step-Side http://67-72chevytrucks.com/vboard/s...d.php?t=552980 1970 LWB http://67-72chevytrucks.com/vboard/s...d.php?t=584499 1970 SWB One Owner Step Side 6.0 LY6/6L90 http://67-72chevytrucks.com/vboard/s...d.php?t=617630 Junkyard's 1971 short wide http://67-72chevytrucks.com/vboard/s...86#post7531186 |
3/4" works well. Make sure the measurements are taken at ride height.
POP
2016 RAM Laramie HEMI 1966 Fairlane GT/A, 390/335 HP If it costs you a dollar to make a friend, KEEP THE DOLLAR. If it costs you a friend to make a dollar, KEEP THE FRIEND. |
Agree ask your drive line shop they all have there own beliefs, my shop uses 5/8 as play , And remember as No neck stated Take mesurement at ride height , My drive line shop tells me this is the Number one mistake made , you can not take your mesurement with the truck on jack stands it MUST BE ON THE GROUND . and the 60'' sounds to long , TH 350 and th 400 and 200 4 r trans from my experience were all under 60 inches.
How about ride weight? Should I wait until the bed is on before I take measurements?
I pulled my yoke out 3/4 measured from center of u joint to center of u joint and went to the wrecking yard. They usually have a huge pile of drive shafts. I found one in excellent condition. I painted it and put new u joints in it and for 80 bucks I was back in business. There is a u joint that uses early model chevy caps and later model chevy caps so everything fits perfectly. The newer caps are a little bigger.
Most drive line shops have a tutorial on how to measure with a downloadable form to put all the measurements on.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
#14 | ||
I was a driveline development engineer for GM Truck, and my shop still sent me back to do the measurements "their way". K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
#15 |
![]() Join Date: Jun 2005
59.5 for my 70 C/10 with 402/TH400
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Sliding Rear Window Power Windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
#16 |
https://www.southwestspeed.com/?sec=...hafts&ssub=!!2 1/2" Steel Driveshafts
#17 | |
#18 |
I bought my driveshaft from Tatton's in Utah off the internet.
Great customer service, fast turnaround and I think I paid around $250 for it to be shipped to my door.
#19 | |
So if I was measuring 60" u-joint to u-joint and they're accounting for 1" of slip, then 59" should be correct right???
#20 |
That's how I measured to, don't remember the numbers, didn't even ask them what size they were sending me, guess I trust people to much, it fit perfect.
#21 |
That’s reassuring, fingers crossed.
#22 |
My 70 GMC short bed had the 2 piece with a bearing at the joint. I replaced with a well balanced one piece and it made a huge difference. Much smoother.
#23 |
![]() Join Date: Sep 2005
When i had mine cut down i was told from the hard part of the seal to the center of the ujoint
#24 |
![]() Join Date: Oct 2017
Guys I have a question about the Southwest speed drive shafts. Could I buy two of them to make a two piece drive shaft? The size I would need for a one piece is about 69 inches long and they dont make one that long.
67 C10 "Big Red" |
#25 |
They can build whatever you want but they're only responsible for the build, not the application.
