Old 02-27-2018, 07:04 PM   #1
jagwarman
1971 c10 gauge cluster
I have a basic gauge package in my 71 c10 being speedo and fuel and in the center two idiot lights with turn indicators. I bought a used gauge cluster out of A 72 c10 super cheyanne that also has temp oil pressure and volts. My question is will my wiring that went to the basic gauges work on the better gauge package?
jagwarman is offline   Reply With Quote
Old 02-27-2018, 07:13 PM   #2
Hutch
Hutch's Avatar
Re: 1971 c10 gauge cluster
jagwarman
You will need to modify the wiring at the connector
Check this link under tips for the wiring change
http://www.gmcpauls.com/Tech%20Tips1.htm
John Hutchison
Grapevine,Texas
68 1/2 t swb
68 Mustang
69 Jaguar
71 1/2 t swb
88 Supra CompTs6m
93 Escort GT
2005 Corolla XRS
Hutch is offline   Reply With Quote
Old 02-27-2018, 07:25 PM   #3
jagwarman
I will look at this link. Thank you
Old 02-27-2018, 10:26 PM   #4
TBONE1964
Cluster King
TBONE1964's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=645940
Also check out this thread. It will explain how to change the terminals from one location to the next in the connector.
Everything you need is there minus the wiring for the amp gauge which is terminal 1 and 12 in the connector.
I offer volt gauge conversions as well which eliminate the amp gauge and the need for amp gauge wiring.
Let me know if you have any questions. I have helps a lot of members here do the exact same thing.
Take care,
Tom
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com
I am also a dealer for Counterpart for gauge cluster parts only.
Also see my facebook page, CG&C
TBONE1964 is offline   Reply With Quote
Old 02-27-2018, 10:38 PM   #5
jagwarman
Thanks so much for the help.
Old 02-27-2018, 10:57 PM   #6
jagwarman
I have also done away with the voltage regulator and converted to a 1 wire alternator which is not even running to the current idiot light. That will have to be sorted.
Old 02-28-2018, 12:37 AM   #7
VetteVet
Msgt USAF Ret
VetteVet's Avatar
The one-wire alternator will not work the idiot light which has to be connected to the white wire from the external voltage regulator and then to the alternator.
The ammeter or the voltmeter will work with the one-wire alternator if they are correctly wired into the harness.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
