Old 03-04-2018, 10:21 PM   #1
rjs53
another disc brake conversion question
Was wondering if anyone has found a complete disc brake conversion kit that has, 2" drop spindles, rotor/caliper all the hardware that doesn't make the wheel stickout further? Also would like a lowering kit that's has everything complete.
2003 Dodge 2500
1969 C10
2014 Camaro SS/RS/1LE
rjs53 is offline   Reply With Quote
Old 03-04-2018, 10:33 PM   #2
flashed
Re: another disc brake conversion question
Im in to see what you find .
flashed is offline   Reply With Quote
Old 03-04-2018, 10:58 PM   #3
rjs53
Started to order a kit a couple days ago, and noticed it said makes the wheel stick out further. Thought someone might have overcome this problem.
2003 Dodge 2500
1969 C10
Old 03-04-2018, 11:21 PM   #4
keel056
I thought CPP has a kit that does not alter the stance
keel056 is offline   Reply With Quote
Old 03-04-2018, 11:33 PM   #5
Drummerboy
Drummerboy's Avatar
I'm running this one. Wheels sit perfectly.
https://www.summitracing.com/parts/s...RoCuKUQAvD_BwE
Drummerboy is offline   Reply With Quote
Old 03-05-2018, 08:28 AM   #6
rjs53
I'll check them out, thank you for the information
2003 Dodge 2500
1969 C10
Old 03-05-2018, 12:47 PM   #7
demian5
demian5's Avatar
This one doesn't list for a truck. So you are running 5x5.75 lug patterns on the front? Did you have the rear axles re drilled?
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 03-05-2018, 10:35 PM   #8
rjs53
The last response brings up another question, what bolt pattern is Chevy truck? I figured seems its Chevy half ton it would be 5x5 3/4. I know not all are, even now but what the heck is it?
2003 Dodge 2500
1969 C10
Old 03-06-2018, 09:45 AM   #9
clay68c10
clay68c10's Avatar
5 on 5 for GM 2wd trucks and vans from 71 up to the early 90s
Big GM cars are that pattern from the 60s to the 80s
Also big Ford & Lincoln cars through out the 70s. Lots of possibilities for 9” rears if you want to go thru the work to swap one.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 03-06-2018, 09:49 AM   #10
rjs53
Good to know thank you
2003 Dodge 2500
1969 C10
Old 03-07-2018, 09:19 PM   #11
jbice70gmc
jbice70gmc's Avatar
Just purchased this day before yesterday.
https://www.azproperformance.com/Pro...liper-C10.html
This kit comes with 2 1/2" lowering spindles though. Not sure if that is optional.
1969 GMC SWB Fleetside
http://67-72chevytrucks.com/vboard/s...d.php?t=486320
jbice70gmc is offline   Reply With Quote
