03-11-2018, 12:46 PM | #1 |
Set timing?
Is setting the timing on a ls after a cam swap as simple as lining up the dot on the crank gear and arrow on the cam gear? Engine is a L92 with vvt. Is is possible to be 360 degrees off?
68 c10- Under construction |
03-11-2018, 02:07 PM | #2 |
Re: Set timing?
dot to dot....https://www.autoserviceprofessional....e-gm-ls-engine
03-11-2018, 04:45 PM | #3 |
Re: Set timing?
Vtt Phaser has a arrow and a straight line. From what I have read the arrow is used in setting timing
