Original Jack
Just wondering how many of you have that wonder stock jack with all the mounting hardware and handle?
Do you actually have it mounted in your cab? ![]()
1970 GMC 2500 700R Trans, RideTech 4 link rear suspension, air bagged on all four corners, factory upper/lower A-Arms, 2 inch drop spindles. 350 SBC 300hp Weiand Supercharger FiTech 30004 EFI |
Re: Original Jack
Yep,still in the corner.Never have used it.
Who Changed This?
![]() Join Date: Jan 2013
Re: Original Jack
I went camping a little over a year ago without checking that I had a jack. I had new tires and didn't run over anything, though one of the guys ended up with TWO flat tires. I'll be better prepared for the next time!
![]() ![]() Join Date: Feb 2009
Re: Original Jack
Everything was lost when I bought my project truck. Someone swiped or swapped, it had an era correct jack instead. Fit just as well on the floor as the original, and didn't require a long*&% handle. Nice jack, but the rebuild is original.
My driver had everything when I got it, including the bag. Can't speak for my project truck, but the bag on my driver is under the passenger seat. It's convenient, and probably kinder to the bag, though perhaps more dangerous. That said, cab corners have holes in them ![]() Come to think of it, my driver has a breaker bar with a socket on it too. Better than a lug wrench.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 03-12-2018 at 12:14 AM. |
Re: Original Jack
I still have all of the stuff in the original bag. It was mounted in the corner but I removed it to put a speaker in there.
![]() Join Date: Aug 2016
Re: Original Jack
I have the spot for it in my truck but the jack and handle are missing
Re: Original Jack
Pulled mine out to put a Bose sub box in the corner. Bagged and Tagged
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
![]() Join Date: Feb 2016
Re: Original Jack
After I found a newer replacement and mounted under the hood I found a complete set up for my Burban at a wrecking yard. Got it and now I'm Mr. Overkill with two jacks!
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
