![]() Join Date: Oct 2017
Shifter for 4 speed Saginaw Car Trans
Upgrading my three on the tree to a saginaw 4 speed I got for free out of a nova. I am already sourcing the drive shaft but I will also need a shifter for it too. I dont want to spend $500 on a hurst shifter because it's just going behind a 250 and a saginaw. I was thinking of using OER #6264024 as an alternative as it was made for that exact transmission. I'm curious though if it will be to short since I put in updated seats from a 2002 Tahoe. Or, Do you guys know of any other shifter that wont cost a ton of money and will work or would this be ok?
https://www.classicindustries.com/pr...s/6264024.html
67 C10 "Big Red" |
Re: Shifter for 4 speed Saginaw Car Trans
Does your sag have the 3 hole mounting flange on the tailhouse?
If so any 4 speed shifter will work. If not you’ll need a mounting kit. |
#3 | |
It's a 441 thats referenced from Hurst website. So yes it has the 3 hole mounting flange. Do you recommend a different shifter that would be better suited for C10s?
67 C10 "Big Red" |
Your seats might be a problem.
The stock seat is tight to the shifter too. You need a bench seat shifter. Like this. https://www.ebay.com/itm/1955-1956-1...BakCLi&vxp=mtr Should be able to find a used one. |
#5 | |
67 C10 "Big Red" |
You need the sag linkage because of the reverse arm location.
You could use a Muncie shifter and modify the linkage if needed. Make your own reverse rod. |
#7 | |
Here's a link to both: https://www.ebay.com/itm/123002527168 https://www.ebay.com/itm/292468017065 Now let's hope I have everything I need to turn my 4 bolt saginaw three on the tree to a 7 bolt saginaw from a car. I have a 71 drive shaft from a three speed truck coming so now it would be a matter of bolting up the trans and drive shaft, right?
67 C10 "Big Red" |
