Old 04-10-2018, 11:42 AM   #1
67chevemall
67chevemall's Avatar
Under column wire?
Anybody know what this dark green plug is for?
Is is under the dash column.
Came with a toggle switch connecting the two sides but nothing is turning on.....
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 04-10-2018, 11:56 AM   #2
Andy4639
Old member
Andy4639's Avatar
Re: Under column wire?
Look to see if the back up lights are coming on per the schematic. I circled it you will have to down load it and blow it up.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 04-10-2018, 12:07 PM   #3
'70_402
'70_402's Avatar
Do you have a high res version of this photo that you can send me??
'70_402 is offline   Reply With Quote
Old 04-10-2018, 12:11 PM   #4
randy500
Reverse lights, your column is missing the neutral safet/back up light switch.
It mounts in the slot on top of the column, part of the slot is shown in your picture.
randy500 is offline   Reply With Quote
Old 04-10-2018, 12:13 PM   #5
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Under column wire?
It's the one off the electrical section.
The connection just left of the turn signal connector.
2-Green wires are back up and 2 purple wires are neutral safety.
Old 04-10-2018, 12:15 PM   #6
Boog
laying low
Boog's Avatar
Andys got it.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 04-10-2018, 12:39 PM   #7
67chevemall
Awesome thanks guys. Off to get new toggle switch.
Looks like I am running manual back up lights.
Old 04-10-2018, 01:11 PM   #8
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Or just install the NSS/backup light switch on the column and plug it in. Your NSS (purple wires, same-ish type plug) must have a jumper wire in it if it's not plugged in to the column switch.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 04-10-2018, 01:35 PM   #9
67chevemall
3 speed trans. With no switch on it yet.
I will look for the purple tonight
Old 04-10-2018, 01:56 PM   #10
zosoppp
If it's a manual three speed (on the tree) then all there is, is a reverse switch. The neutral safety switch is only for 3 speed auto columns.
1970 C10 LWB 350SBC, SM330 Muncie (not saginaw SM326) (on tree), 3.07 open (assumed), PS, PB, Idiot lights
zosoppp is offline   Reply With Quote
