Old 08-31-2017, 10:58 AM   #1
5150
C10 Club Tennessee
5150's Avatar
Do I need a different oil pan?
Getting ready to install an LS in my 87 squarebody. Not sure if I can get away with using this oil pan. Truck is lowered 5/7. In my 71 burb I had to change the pan, but wanted to ask before I sit it down inside the truck.
Bryan
www.gmtruckshow.com
Project "Andes"-Halen's First Truck
Project: Patina Burb
for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4
5150 is offline   Reply With Quote
Old 08-31-2017, 11:23 AM   #2
ls1nova71
ls1nova71's Avatar
Re: Do I need a different oil pan?
It's most likely going to hang down just as much in an '87 as it would have in your '71. If the truck wasn't lowered it would be fine, but since it is, I would at least consider the GM muscle car pan as they're dirt cheap and with the right mounts should put the bottom flush with the crossmember.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 08-31-2017, 03:07 PM   #3
racecougar
racecougar's Avatar
Depends on the tire size you run, what engine mounts you use, what ground clearance you're comfortable with, etc. It will sit an inch or two below the bottom of the engine crossmember.
Rod @ AzzKicker Cars
1965 C10 SWB - Build Thread
racecougar is offline   Reply With Quote
Old 08-31-2017, 06:17 PM   #4
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
IMO with most the setups guys on here are running, you'll want to replace it unless its a stock height truck.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 08-31-2017, 06:25 PM   #5
mongocanfly
mongocanfly's Avatar
my engine came from a escalade and I'm using the stock LS pan in my non lowered 81....its exactly the same level as my crossmember...doesn't hang below it..
Old 08-31-2017, 09:50 PM   #6
72MARIO
72MARIO's Avatar
I would say you definitely need a shorter pan.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 08-31-2017, 10:43 PM   #7
68c10airstream
68c10airstream's Avatar
My 5.3 in my 68 sits about 1/2" above the crossmember using a "F" body oil pan (98-02) and the sump is still above the bottom of the crossmember. I used the organ donor 2001 ls mounts and made my own mount brackets to get the engine as low and to the rear as possible. I like to fab things up sometimes. The bottom of the "F" body oil pan is basically at the same plane as my 4l65e oil pan is.
I believe using dirty dingo adapters and 68 style mounts position tilt the motor up in the front from what i can tell looking at many install photos. Nothing wrong with it but my objective was to get it low and rearward with some fab work. The f body pan is the thinnest of any pan out there at i believe 1.25". My steering center link in the straight ahead position is so close i can barely get my pinky between it and the oil pan.
Sticking my head under the front bumper and looking rearward i have no low hanging fruit, even my exhaust is tucked up including my exhaust "X".
68c10airstream is offline   Reply With Quote
Old 08-31-2017, 10:47 PM   #8
5150
C10 Club Tennessee
5150's Avatar
These are the mounts I will be using.
Bryan
www.gmtruckshow.com
Old 09-02-2017, 09:26 PM   #9
Steve Cole
I would say you need a shorter pan. I went with the CTS-V pan. Improved Racing has the best price on the complete pan swap.
BTW... those headers look awesome! What are they????
Steve Cole is offline   Reply With Quote
Old 09-03-2017, 01:06 AM   #10
5150
C10 Club Tennessee
5150's Avatar
Found them on ebay.
http://www.ebay.com/itm/C-10-LS-Chev...53.m1438.l2649
Bryan
www.gmtruckshow.com
Old 09-14-2017, 08:27 PM   #11
5150
C10 Club Tennessee
5150's Avatar
Can you guys post a link to a pan that will work? Do the muscle car pans work? I can't tell if they are any different than the the pan I have on it now.
Bryan
www.gmtruckshow.com
Old 09-14-2017, 09:31 PM   #12
72MARIO
72MARIO's Avatar
In my build thread all the part numbers are listed
2005 TAHOE DD
Old 09-14-2017, 09:45 PM   #13
1957 Chief
Like others have said, change that pan. My son's truck had that pan with a 5/7 drop. he scraped it a few times...and I was always concerned. Better do it now while its easy. Once its in the truck its won't be.
Bubba
1957 Chief is offline   Reply With Quote
Old 09-28-2017, 08:34 AM   #14
Green67Stepper
Green67Stepper's Avatar
Bryan, with as low as your squarebody is, i'd get a new pan. I've got the GM Muscle Car pan from Jegs for $200. The Holley pan is nice too for $300.
Green67Stepper is offline   Reply With Quote
Old 09-28-2017, 03:47 PM   #15
Steve Cole
The muscle car pan is only .75" shorter than the truck pan. Not worth the expense in my opinion. The CTS-V or the F-Body is a much better option.
Old 09-28-2017, 07:40 PM   #16
67LS3GMC
Like some others have said the CTS-V works best. - Part Numbers -
Oil pan:
12631828
Pickup tube:
12621299
Windage tray:
12611129
Dip stick:
12584737
Dip stick tube:
12584738
Pickup tube o-ring:
12557752
Gasket:
12612350
67LS3GMC is offline   Reply With Quote
Old 04-16-2018, 08:53 AM   #17
mcbassin
Still Learning
mcbassin's Avatar
Has anyone used this kit from Summit racing?
https://www.summitracing.com/parts/nal-19212593
Old 04-16-2018, 10:01 AM   #18
ls1nova71
ls1nova71's Avatar
That's the GM muscle car pan I mentioned at the beginning of this thread. I have used it and it is just about even with the crossmember.
Old 04-16-2018, 11:27 AM   #19
mcbassin
Still Learning
mcbassin's Avatar
Thanks for bringing that to my attention.
What motor mounts did you use on your swaps? I am using the clamshell style with mine. Right now my pan hangs below the crossmember about 1-3/4- 2".
Old 04-16-2018, 08:04 PM   #20
ls1nova71
ls1nova71's Avatar
I made my own mounts, so that a truck pan is only about an inch below the crossmember, which put the muscle car pan flush. If you're that far below ir, then the muscle car pan may still hang down 3/4" or so.
Old 04-16-2018, 10:17 PM   #21
mcbassin
Still Learning
mcbassin's Avatar
Yep, I measured it today. I'm going to bite the bullet and buy the CTS pan setup. Damn, I wasn't wanting to drop that much cash on an oil pan. I've bought complete engines for less....
thanks for the help.
Old 04-17-2018, 04:14 PM   #22
verdell
verdell's Avatar
The F-body oil pan is currently $179.00 at Advance Auto. I plan on starting my swap when I return from Pigeon Forge the weekend and this is the pan I'm using. Keep in mind, this is just the bare pan but I think the price is pretty close to or cheaper than a CTS-V. The muscle car maybe cheaper but the F-body GMP77A is shorter. I know a couple of guys with '87 LS short beds and I think the stock pan is absolutely to low for a lowered truck.
verdell is offline   Reply With Quote
Old 04-18-2018, 01:26 AM   #23
5150
C10 Club Tennessee
5150's Avatar
Don't get suckered into a lower price with just the pan. You're going to need the pickup tube and windage tray. Some times you can modify your current windage tray.
Bryan
www.gmtruckshow.com
Old 04-23-2018, 01:15 PM   #24
mcbassin
Still Learning
mcbassin's Avatar
From my research the windage tray is the same for the truck and the CTSV.
Is that not the case?
Old 04-23-2018, 03:48 PM   #25
StingRay
StingRay's Avatar
That's my understanding. There is a change up number on the tray somewhere along the line but when I bought my CTSV parts which are not installed yet I didn't buy the tray expecting I'll use my truck one.
Saskatoon, Saskatchewan
Canada
StingRay is offline   Reply With Quote
