Old 02-23-2023, 08:54 PM   #1
chev-obsession
chev-obsession's Avatar
which brake master for hydro boost
I am converting to hydro boost and have disc/disc setup. Which brake master cylinder should I be running?
1965 c/10 swb
1969 c/10 lwb
chev-obsession is offline   Reply With Quote
Old 02-24-2023, 10:31 AM   #2
MT65
Re: which brake master for hydro boost
Your best information will come from a manufacturer of good brake components…Master Power Brakes would be your best bet…to many variables on caliper bore size.. I used a 1” bore for many cars, then on the last one I used wilwoods on the rear and large piston GM on the front…not enough volume, had to go to 1 1/8 bore..problem solved…
MT65 is offline   Reply With Quote
