Old 04-28-2018, 09:52 PM   #1
demian5
demian5's Avatar
Lower control arm shaft replacement 70 c10 help
So I’m replacing the lower control arm shafts on my truck. What a pain in the ass. 1-5/8” socket? Good luck, got a big ass crescent wrench from harbor freight...
Anyways got them changed, the passenger side is smooth and falls on its own when pulled up, I had to keep tightening it till the slop was out of it though.
The driver side, from the start was hard to tighten and once tight, is very hard to move up and down. I’m thinking that it will loosen after time, but which is right?
Should they both be really tight or really loose and free?
Shafts are centered, I greased them (driver side not before installing, passenger side had some kind of lube on it). I’m not ok leaving it lie this, something is wrong.
Help
demian5 is offline   Reply With Quote
Old 04-28-2018, 10:23 PM   #2
Pro299
Junior Member
Re: Lower control arm shaft replacement 70 c10 help
I think if they're centered pretty well they should be ok. I had the same concern when I did mine last year. I tried to get the shaft oriented with the index best I could before tightening down. Had to push pretty hard to get the arm down for installing the spring. I have a few hundred miles on mine since then. Seems to be ok so far.
Pro299 is offline   Reply With Quote
Old 04-28-2018, 10:26 PM   #3
demian5
demian5's Avatar
Thanks, then my concern may be the loose one I think. Do I need to get a breaker bar and pinch the control arm ears inward to get it tighter?
Old 04-28-2018, 10:32 PM   #4
Pro299
Junior Member
Don't know about that. You said you used a crescent wrench. Do you think you got pretty close to the torque spec? If so, I think I'd just leave it alone.
Old 04-29-2018, 01:01 AM   #5
demian5
demian5's Avatar
Well I did use my foot to achieve final tightness till I couldn’t anymore. So one loose one tight but both solid should be ok?
Old 04-29-2018, 08:49 AM   #6
rjs53
Were they like this when you started? I'm getting ready to change mine, so this helps.
2003 Dodge 2500
1969 C10
2014 Camaro SS/RS/1LE
rjs53 is offline   Reply With Quote
Old 04-29-2018, 09:44 AM   #7
demian5
demian5's Avatar
The original rear bushings had play in them. That’s why I replaced them.
Old 04-29-2018, 09:45 AM   #8
demian5
demian5's Avatar
What’s the torque spec?
Old 04-29-2018, 11:49 AM   #9
davepl
davepl's Avatar
You need to consult a shop manual for this. I think the 3/4 tons are like 155 lb-ft and you won't do it with a crescent wrench, I don't think.
Plus it has all the steps on how to keep it centered and so on. Here's one page, it's well worth having...
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 04-29-2018, 12:15 PM   #10
demian5
demian5's Avatar
So I’m thinking about it, and the tight one, if I loosen just one of the ends all the way, the one that’s still tight will keep it centered and it should relieve the resistance then I retighten just the one. Hmmm, I think I’ll try and find a socket first though...
Thoughts?
Old 04-29-2018, 05:05 PM   #11
Jason Banks
Jason Banks's Avatar
I just got done doing mine and use an air impact with a socket to get them on. The breaker bar and cheater pipe were killing me. I did grease the threads on the cups before I started. I didn't at first and then had second thoughts and pulled it back apart and put grease. When I got done and put the grease fittings in it didn't take much more grease to fill them up.
I ran them down with the air impact and then went the last little bit with the breaker bar and torque wrench. I'm pretty sure it took more torque than the final torque spec just to get them installed. I did have one that really wouldn't budge once it was tight and ended up loosening the caps a little because I couldn't rotate the shaft to line up the dimple. Put the torque wrench back on and it still clicked after loosening.
I'm not sure exactly what is being torqued here because normally when you are tightening a bolt you are stretching it a certain amount. Those lower shafts are so big I can't imagine they are stretching much.
This thread has some good info:
http://67-72chevytrucks.com/vboard/s...d.php?t=544901
I found that thread because I was looking for what MOOG said to torque the bolts to. 100 ft/lb which is less than the factory manual.
Mine ended up with one arm that would stay in whatever position you put it and one that drooped when you let go. I figured it would be fine since they both moved freely and had grease on the threads.
Jason Banks is offline   Reply With Quote
Old 04-29-2018, 06:39 PM   #12
weq92f
weq92f's Avatar
Mine were about the same after torque and install ( with grease on the threads prior to assembly ). One was real tight and the other was much less tight, both centered. This was achieved with BIG pipe wrench and full body weight with cheater.
It's been fine since so I think you're going to be OK. These parts are so rigid and beefy it'd take a real bad install to create a safety issue ( except maybe for the U-bolts--get carried away with the torque there is not a good idea ).
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 04-30-2018, 01:10 PM   #13
demian5
demian5's Avatar
This looks like its for the uppers so the torque spec of 80 seems unreal for an 1-5/8" suspension nut.
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
Old 05-02-2018, 08:10 AM   #14
demian5
demian5's Avatar
Ok so I got a hold of a socket and a nice sized 3/4” ratchet. I loosened the rear nut on the tight control arm, pulled it off, greased it again, and reinstalled. What do you know, it’s nice and smooth like the passenger side now. All is good!
Old 05-02-2018, 10:47 AM   #15
davepl
davepl's Avatar
When I did mine I counted each rotation or partial rotation so that the caps were turned on the exact same number of turns. Don't know if that's the "right" way to do it, but the wheels haven't fallen off yet!
