Old 06-02-2018, 04:37 PM   #1
Nodnarb76
Nodnarb76's Avatar
Lowering a 3/4 Suburban
How much of a drop do I need to to make mine (red/tan), look like the blue one?
1987 R20 Suburban LQ4/4L80e swap: http://67-72chevytrucks.com/vboard/s...d.php?t=693824
Nodnarb76 is offline   Reply With Quote
Old 06-04-2018, 03:14 AM   #2
Crank
Crank's Avatar
Re: Lowering a 3/4 Suburban
I’d also be interested in knowing. I’d say at least a 5/7. That thing is pretty dang low.
Crank is offline   Reply With Quote
Old 06-12-2018, 08:30 PM   #3
Ziegelsteinfaust
Also if you go to a 5-7 drop. Check if you have a 14 bolt FF or SF rear end. The smaller semi floater still is 8 lugs, but also give needed room for a deeper drop. Before you cut into the body.
Ziegelsteinfaust is offline   Reply With Quote
