Splitting a 68 C10 Trailing Arm
I can’t afford an aftermarket tubular arm set and would like to keep my original arms. That said, I have a lot of built up rust inside of the arms and am wondering if anyone has ever split their trailing arms to clean out the inside. How is it done exactly? It appears that I have some rivets that go all the way through and some that don’t. Thanks in advance!
1953 Kaiser Manhattan “Sled” 1968 C10 CST LWB 1991 Trans Am GTA “White Nasty” 2006 Dodge Charger RT Built TH400 for Sale |
![]() Join Date: Mar 2018
Re: Splitting a 68 C10 Trailing Arm
Clean them up as best you can and hit them with an epoxy and paint or some type of rust inhibitor. But before you paint I would tack weld the arms on both sides.
1969 C-10 LWB SS 1969 Camaro Pro Tour 2002 Camaro SS LE Rag Top #937 |
Guest
Posts: n/a
I highly recommend BlackStar rust converter— stops the rust and turns part into a nice patina dark brownish black. Lots of other good options out there as well.
I separated mine...if I remember there were some spot welds to drill out and maybe some rivets. I wire brushed them real good and sand blasted where needed. I then treated the metal with Ospho rust converter and painted them. Then bolted them back together with grade 8 hardware in every place they were originally connected.
Another option would be to use electrolysis - those electrons can fit in the space between the halves of the trailing arm no problem and will get rid of the rust with no acid residue.
I would submerge the arm in a concrete mixing tub full of water and a half cup of Washing Soda and connect the trailing arm up to the negative clamp of a battery charger. Then the positive clamp to a piece of mild steel approximately the same surface area as the trailing arm. I use the two amp setting; even for larger parts like this - from the photo I'd say it would take about 8 or 10 hours in the tub - faster if you can position ) the mild steel piece close (1 inch) to the rusty part without risking it touching. |
#6 | |
This is likely what I’ll do. I have some chassis saver paint from my frame, and I think I’m just going to send it and save for some new arms in the future.
#8 | |
1953 Kaiser Manhattan “Sled” 1968 C10 CST LWB 1991 Trans Am GTA “White Nasty” 2006 Dodge Charger RT Built TH400 for Sale Last edited by WhiteCST; 06-15-2019 at 04:47 PM. |
![]() Join Date: Dec 2013
Why ? if they aren't blistering all you have to do is media blast them and run a few welds and be done with it , Some epoxy prime and paint and your done .
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
#10 | |
![]() Join Date: Feb 2019
Electrolysis, then take to powder coat.
1968 C20 Fleetside 396 4sp PS PB AC CST . https://www.youtube.com/watch?v=RWK8GgWD4uA |
The Older Generation
I have taken two sets of them apart, blasted them, painted inside and welded them back together. Drill out the rivets/spot welds and separate them with a chisel. Spray the front mounting bolt bushing with a good penetrating oil and twist the individual halves back and forth to get the penetrating oil worked into the bushing and work them apart. Being from Iowa mine were in a lot worse shape than yours though. LockDoc
My first set off a 72 2WD Blazer fell to pieces as I pounded on them with a hammer to loosen the rust flakes.
I have modified 3 sets of these using Early Classic top and bottom plates. I heard they are a modification for a 3/4 ton. Clean the old arms then you might even run a bead down the mating surfaces top and bottom. I added that step because I have a couple of 220 welders so no money spent just time. The plates are about 3/16 steel with holes punched for the U-bolts. They weld on top and bottom and really add a lot of strength to the stock arms. Price was very reasonable and a bonus is they come with new U bolts and new front pivot bushings. Might be dreaming and might be the new springs but I think the ride and especially cornering felt tighter with a stronger arm. |
