Old 03-19-2011, 05:44 PM   #1
81ShrtBox
MadMan
81ShrtBox's Avatar
Need help putting 2002 Z06 brakes on a 81 C-10
I want to use everything and anything I can off of this donor car... I would love to use the Z06 brake setup but I'm afraid of running up against a wall. And I know it will narrow my wheel choices with the oversized calibers and rotors. If any of you guys have successfully completed this swap please post some pics and give some info....PLEASE....PRETTY PLEASE...
81" Shortbed C10 Full Restoration underway, who needs a budget?? LS Pro Touring Build
81ShrtBox is offline   Reply With Quote
Old 03-19-2011, 06:01 PM   #2
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
Re: Need help putting 2002 Z06 brakes on a 81 C-10
Ive done the rear conversion, not the front... yet.
with the Corvette rotors, a stock ralley barley makes contact with the caliper bracket.... a 1/8 spacer would eliminate the problem. You could also swap to a corvette, non directional vein rotor but you would have to space the caliper accordingly.
http://67-72chevytrucks.com/vboard/s...=415021&page=2
clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
Old 03-20-2011, 03:32 PM   #3
81ShrtBox
MadMan
81ShrtBox's Avatar
Thanks for the info... this is exactly the kind of feedback i'm looking for. What about the big rotors up front?? I want to install all 4 rotors and calibers
Old 03-20-2011, 09:20 PM   #4
N2TRUX
Happy to be here
N2TRUX's Avatar
Contact way2lo2. If anyone here knows how, he does.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 03-20-2011, 11:45 PM   #5
muthstryker
muthstryker's Avatar
It wont narrow your wheel choice, it will open it up ALOT. There are way more wheels for the 5x4.75 lug pattern then there is the 5x5 pattern. If I were you, I would contact Tobin at Kore3. He will be able to help you out with everything.
http://www.kore3.com/
muthstryker is offline   Reply With Quote
Old 03-21-2011, 12:17 AM   #6
maynardtruckin
maynardtruckin's Avatar
just put the hole rear irs in your truck and swap out front suspension!I did that on my 67 I just used older vet stuff but the second gen irs is easer to work with and it makes for a much better ride!
Chris
67 c10 swb build in progress
70 c10 lwb driver pending parts for drastic overhaul
70 c20 lwb parts truck for above mentioned drastic overhaul
71 k20 lwb building for off road use and towing
maynardtruckin is offline   Reply With Quote
Old 03-30-2011, 09:04 PM   #7
way2lo2
way2lo2
way2lo2's Avatar
If you mean Z06 brakes like this, I can help as long as you want drop spindles, if you don't want drop spindles, I can still help but you'll have to send me your spindles to do it.
Dealer for Billet Specialties, Ridetech, Airlift, Vintage Air and others. Feel free to call, email, or PM for a quote.
216 481-5219 office
216 481-4240 fax
216 789-1647 mobile
Way2Lo2@aol.com <----also my paypal
http://www.hubgarage.com/mygarage/way2Lo2
way2lo2 is offline   Reply With Quote
Old 03-30-2011, 09:30 PM   #8
paul66c10
paul66c10's Avatar
Would love some more information about this for my 86 but i already have dropped spindles and i was wondering if i could use the brakes off my Z06 when i upgrade to the newer Z06 brakes.
1986 gmc shortbed (right now its rough) porterbuilt dropmember front mmw flat plate uppers and lowers, soon to have porterbuilt rear dropmember, painted cherry red rallies, flat green primer in the works with a gloss white roof, 92 civic dx daily beater, 01 z06 new toy
paul66c10 is offline   Reply With Quote
Old 03-30-2011, 09:36 PM   #9
way2lo2
way2lo2
way2lo2's Avatar
any c5 or c6 brake option will work as long you use the calipers and rotors from the same brake option. Our brackets will work with Mcgauphys spindles but they will need to be machined which we can do for you or we have already machined spindles in stock.
216 481-5219 office
216 481-4240 fax
216 789-1647 mobile
Old 03-30-2011, 09:46 PM   #10
way2lo2
way2lo2
way2lo2's Avatar
machined spindle and brackets
216 481-5219 office
216 481-4240 fax
216 789-1647 mobile
Old 04-01-2011, 05:25 AM   #11
81ShrtBox
MadMan
81ShrtBox's Avatar
I love this site
Thanks....
Old 04-01-2011, 01:46 PM   #12
ProStreet83C10
Drag Racer
ProStreet83C10's Avatar
wow thats cool, so does that mean our bolt pattern changes or is it still 5x5 for us half ton 2wd guys
Zach Hall
1983 Chevy C10
R/T: .194
60': 2.322
330: 6.379
1/8: 9.803
MPH: 71.37
1000: 12.781
1/4: 15.314
MPH: 88.79
ProStreet83C10 is offline   Reply With Quote
Old 04-01-2011, 09:19 PM   #13
kelsfine69
18 Till I Die
kelsfine69's Avatar
Im Watchin this...Will thes work for us 15" Torque Thrust Guys?.
2011 GMC Acadia
1969 GMC BBC LS7
2007 GMC Crew Duramax
1987 Camaro Iroc 350 Tuned Port Injection
42000Km
1987 Chevrolet Silverado 350 TBI
1987 Chevrolet Silverado 350 TBI(yes 2)
Take me drunk, I'm too home...
kelsfine69 is offline   Reply With Quote
Old 04-01-2011, 10:02 PM   #14
81ShrtBox
MadMan
81ShrtBox's Avatar
Dont think so.... rotors probably too big for a 15" rim. I'm going 22"/24" stagger Dont want it looking crazy with the small rotors
Old 04-01-2011, 10:29 PM   #15
N2TRUX
Happy to be here
N2TRUX's Avatar
Im Watchin this...Will these work for us 15" Torque Thrust Guys?.
Not even close. I think they will require at least a 18" wheel.
Articles-
"Refining Sierra"
Old 04-01-2011, 10:36 PM   #16
87chevy.com
Im sure they dont. The rears are only a 12" rotor and the factory steel wheel barley fits... actually touches the caliper mounting bracket a little. The only way the rears would fit no prob is if I redid the spacer for the caliper mount and use a camaro rotor... but no way on the fronts... maybe if you ran skinnies... but skinnies and squares isnt practical,
clint
Old 06-23-2013, 10:03 PM   #17
81ShrtBox
MadMan
81ShrtBox's Avatar
brake upgrade will be a must with the new engine... time to start putting parts together
Old 06-23-2013, 11:48 PM   #18
81ShrtBox
MadMan
81ShrtBox's Avatar
I have 2002 C5 slotted and drilled rotors and calibers.. I will need the caliber brackets too right?? I already had drop spindles.. So will I still need anything machined??
I'm still trying to figure out whats all needed for the rear conversion too
Old 06-24-2013, 01:39 AM   #19
87chevy.com
Rear calipers rotors ebrake plate assembly, a conversion kit and either machined original axles or new axles with a smaller flange o.d. and hub diameter of a camaro/corvette. I have one kit left for the rear.
Clint
Old 06-24-2013, 01:54 AM   #20
81ShrtBox
MadMan
81ShrtBox's Avatar
how much for the rear kit?????
Old 06-20-2018, 04:33 AM   #21
81ShrtBox
MadMan
81ShrtBox's Avatar
Ok.. this is what I ended up with
1. Cadillac Eldorado rear caliper
2. Flebay rear disc conversion bracket kit
3. Had axles machined to fit the rear rotors
4. Flebay slot/drilled Cadillac rear rotor
5. OEM front caliper (new)
6. C10 slot/drilled front rotor
7. Rockauto front and rear brake hoses
8. All new custom bent brake lines
Old 06-20-2018, 04:36 AM   #22
81ShrtBox
MadMan
81ShrtBox's Avatar
Looks better than expected.
Old 06-20-2018, 04:42 AM   #23
81ShrtBox
MadMan
81ShrtBox's Avatar
I ended up using the cadillac rear and OEM C10 front for ease of parts. It was much easier this way. I was getting frustrated trying to complete the other setup
Old 06-20-2018, 04:45 AM   #24
81ShrtBox
MadMan
81ShrtBox's Avatar
My front rotors should be in today. I recieved a set of 6lug rotors the 1st time
Old 06-20-2018, 04:47 AM   #25
81ShrtBox
MadMan
81ShrtBox's Avatar
This kit does keep the ebrake.. that was important
