![]() Join Date: Apr 2014
Blazer body shim vs core support
Wondering which way would be the better way to go. I either need to shim my core support up or take body shims out to get my front fender and door alignment. Any input is appreciated.
72 GMC Suburban (dads) 69 SWB Chev (frame off father/son) 70 2wd Jimmy+69 4WD Blazer = PHASED 71 SWB stuffed in the barn |
Re: Blazer body shim vs core support
Going to be really hard to diagnose problems like this but I know the B pilar alignment/shim is pretty critical.
First question though - do you have NEW body mounts in and is the top on? |
Body mounts are brand new. Ordered one of the full rubber sets from classic heartbeat I believe. I replaced the shims exactly as the were before. The top will not be going back on.
hows the door to b-pillar alignment?
If thats good then keep moving forward towards the front of the truck. |
B pillar alignment is good, was a little bit of a pain but got it in place
Tub/body shims get done first for correct door alignment. The last body mounts to be adjusted are the rad support ones. Do it out of sequence and you'll end up with a can of worms.
Vintage Evil
Are there any write ups on this? I just put mine back where they were as well... But am just starting to put doors etc on... and not sure what the PO might have done...
Current Rides: Vintage Evil - 72 Chevy C10 (Always a work in progress) Vintage Evil Build Thread EvilK5 - 71 K5 Blazer Evil Twin - 2006 Suzuki M109R EvilDmax- 2018 GMC 2500 Denali Duramax |
It's written about in the factory assembly manual. Maybe someone can post a pic. Also I do recall seeing it in previous threads - try searching.
OK sooo. I'm going to go ahead and shim the core support then. Next question are there specific shims for accomplishing this, as mine had none before. Can I use body shims in the core support locations? What about some suburban/truck rubber mounting pads?
Would love to see the factory procedure as well, anyone want to share?
FWIW, it's been 3 years since the restoration, and I developed a small rattle in the driver's door latch area. I noticed the gap at the rear of the door was not parallel anymore and was wider at the top. I loosened the rear body mount on the driver's side as well as the one in front of it by the filler neck of the fuel tank. I added a 1/4" shim in both and tightened it back up. This was enough to get rid of the wide gap as well as the rattle by the latch.
Vintage Evil
Is this the page you guys are referring to? Not much info here...
Vintage Evil
Anyone?
#15 |
I dont believe it is, looking for the alignment of fenders to doors. whether to shim the core support or take the body shims out
#16 |
Subscribed
#17 |
That has already been answered for you ! The core support shims will align the fenders to the front of the doors. It's really not rocket science. Don't touch the body tub shims unless you have door to body issues. Not trying to be rude, but if you can't visualize what needs to be done, then maybe it's best that you take it to someone that knows what to do.
#18 | |
#19 | |
Vintage Evil
#20 |
Let me dig out my book...
#21 |
Vintage Evil
#22 |
![]() Join Date: Nov 2013
This is from the factory assembly manual
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. ![]() |
#23 |
thats it.
#24 | |
Vintage Evil
