Old 06-20-2018, 11:28 PM   #1
Old_iron
Steering stabilizer / dampener
I am finishing up my rebuild of the '72 Dana 44. The original tie rod was shot so I picked up a nice, straight, used one from a newer model (maybe later 70's, 80's) D44.
Now that I have it together, it seems obvious that the steering stabilizer mount on the axle tube will have to be cut off and moved if I want to use it in conjunction with the hole in the tie rod.
Is that right? Would you do that or just not use it? The truck will be lifted 4".
1968 GMC 3/4 Ton 4x4 K20 / 2500
1971 Chevrolet Chevelle Malibu
Old_iron is offline   Reply With Quote
Old 06-21-2018, 09:45 AM   #2
68panelman
68panelman's Avatar
Re: Steering stabilizer / dampener
Use the clamp on style tie rod bracket and utilize the factory axle mount.
68panelman is offline   Reply With Quote
Old 06-21-2018, 11:44 AM   #3
demian5
demian5's Avatar
And High Steer conversion while you are at it.
http://www.fourwheeler.com/how-to/tr...er-conversion/
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 06-21-2018, 12:08 PM   #4
Jeff's bowtie's
Also the newer tierod may not clear your springs as the newer tie rod comes up through the bottom that's why they are straight the 72s are offset on the ends just a thought
Jeff's bowtie's is offline   Reply With Quote
Old 06-22-2018, 12:19 AM   #5
Old_iron
Thanks for the input gents, I'll go out and check the spring clearance also look up the tie rod bracket.
Old 06-22-2018, 07:15 AM   #6
DeadheadNM
Carpe manana
DeadheadNM's Avatar
If it clears you might try using the tie rod and get an OEM clamp. The clamp should bolt further inward than the existing eye hole when using an OEM style dampener. Here are some reference photos: http://67-72chevytrucks.com/vboard/s...9&postcount=57
Old 06-24-2018, 11:18 AM   #7
B. W.
B. W.'s Avatar
Raybestos p/n 410-1003 is the correct tie rod.
Sorry, difficult to see, best pic I have:
B. W. is offline   Reply With Quote
