Old 07-13-2018, 10:44 AM   #1
72c20customcamper
72c20customcamper's Avatar
Redid my bench seat. Not to happy .
Well I did my seats last week . They look great but the foam (PUI) is way to hard for my taste . Never used PUI foam question is will it soften with time or should I bite the bullet a tear into them and install ACI foam?
Old 07-13-2018, 10:56 AM   #2
bill3rail
bill3rail's Avatar
Re: Redid my bench seat. Not to happy .
I don't know about the different brands of foam, but would the cover tear easier if it was subject to more stretch by sitting on softer foam? It would essentially put tension on the seams when your a$$ is on it.
My .02
P.S. It looks beautiful!
1970 C10 8' Fleetside, L6 250, 3 on the Tree.
The most basic of pickup trucks!
bill3rail is offline   Reply With Quote
Old 07-13-2018, 02:51 PM   #3
72c20customcamper
These a very stiff I'm actually sitting higher and my line of sight is just below roof windshield rubber. Very annoying at a stop light feel like I'm in a chopped 32 ford . Much stiffer than my Chevelle that I did a few years ago. But I used legendary . The supplied the skins and foam. Which I believe was from american cushion ind.
Old 07-19-2018, 10:51 AM   #4
ncpetersc
ncpetersc's Avatar
I have this line of sight problem too. It's one of the more uncomfortable things about driving my truck. I never thought abut the foam in the seat though, even though my seat was clearly re-done by the previous owner. I just figured it was characteristic of these trucks with a bench seat, since I had nothing to compare it to. And I'm by no means tall, 5' 10" on a good day.
ncpetersc is offline   Reply With Quote
Old 07-19-2018, 10:55 AM   #5
Bigdav160
Bigdav160's Avatar
I used PUI foam in my sport buckets and I find them a little soft. Sort of wished I put new seat springs too.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 07-19-2018, 02:50 PM   #6
72c20customcamper
Been driving it a few days . Guess my butt is getting used to the foam .Decided to just make some seat mounts so the seat sits on the floor should gain about 2 inches. I never move the seat anyway so being stationary is no big deal.
Old 07-19-2018, 09:02 PM   #7
dmjlambert
dmjlambert's Avatar
Good. Can we see pictures of how you did the seat mounts?
Old 07-19-2018, 09:51 PM   #8
SC1969c10
how would you rate the install? ordered a new cover for mine and am actually a little nervous about attempting
SC1969c10 is offline   Reply With Quote
Old 07-23-2018, 09:01 AM   #9
72c20customcamper
I'll post them when I fab them up. Just got back from the Syracuse nationals car shoe. Great weather and the whole nys fairgrounds was packed with cars.
Old 07-23-2018, 09:07 AM   #10
72c20customcamper
Bench seats are pretty straight forward on any vehicle. Took me about two hours to do. I also had to weld the rail on the back seat bottom. It's just a wire that holds the seat to the frame via the hog clips. Only real problem was the hog clips were a bit to heavy duty. Bought them a tractor supply. Hard to got them closed with upholstery hog clip pliers.
Old 07-23-2018, 10:38 AM   #11
leddzepp
Moderator
leddzepp's Avatar
Zip ties work a whole lot better than wrestling with hog rings.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 07-23-2018, 12:09 PM   #12
davepl
davepl's Avatar
I can't speak to how hard the original foam is, but the line of sight is an interesting one. I have buckets but installed glass with a tinted strip and once I had new upholstery, I looked straight into it, way too high in the cab.
I think we're so used to sitting on clapped out 50 year old seats with compressed foam and even broken or missing springs that we forget they used to sit high originally!
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 07-23-2018, 12:43 PM   #13
OregonNed
OregonNed's Avatar
Mine was re-done a few years ago. Always felt very high afterwards, and I felt high-centered. Using the 2 inch lowering brackets, it is much more comfortable.
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline   Reply With Quote
Old 07-23-2018, 02:00 PM   #14
dmjlambert
dmjlambert's Avatar
What are “the 2 inch lowering brackets“ and how would I get some of those? That sounds like something I would like.
Old 07-23-2018, 02:21 PM   #15
OregonNed
OregonNed's Avatar
Here is the thread about them:
http://67-72chevytrucks.com/vboard/s...d.php?t=758138
Old 07-23-2018, 02:33 PM   #16
72c20customcamper
They are good for getting it started but I don't like using them .
Just doesnt seem permanent.
Old 07-23-2018, 04:01 PM   #17
leddzepp
Moderator
leddzepp's Avatar
Mine have been there for years, zero problems, nylon is uber strong not exposed to uv...so not sure what the problem would be using them
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 07-23-2018, 04:12 PM   #18
72c20customcamper
I still use lead for body work.
