Old 08-24-2018, 08:00 PM   #1
joeydurango
joeydurango's Avatar
NP205 Experts: Knowledge Wanted!
Asked over on the general board 2 months ago but never got this figured out.
My 72 K10 (350/350) has suddenly begun spinning the front driveshaft intermittently when in 2HI. I'll be coasting along down a hill, all's normal, hit a few small bumps, and the vibration appears to cause the case to s l o w l y begin engaging the front shaft. I can hear it, and feel it, catching just the tiniest bit, then increasing engagement.
The front axle and hubs are all good, I rebuilt them a couple years back and checked them again recently. Everything else (shift linkage, all connections, u-joints, driveshaft slip joint) looks/feels completely normal and is tight and solid externally, so I've got some sort of problem inside the dang case.
What part in the NP205 t-case is responsible for keeping the t-case locked in 2HI? Is there a detent spring or something that could have broken, allowing some selection mechanism to "float" between 2HI and 4HI even when the shift lever is solidly in 2HI?
TIA!
1972 K10 Cheyenne Super | LWB, fleetside | 350/350/205 | KEEPER
1971 K10 Cheyenne | SWB, fleetside | LS Swap 5.3/4L60 | SOLD
1976 Trans Am | 400/4-spd | SOLD
1976 Trans Am | 455/4-spd | TOTALED
joeydurango is offline   Reply With Quote
