Old 10-28-2018, 12:09 PM   #1
Red71gmc
Bedside tool box with no key
I have looked over the threads and seen this brought up before but didn't find any answers yet.
I have a locked bedside toolbox with no key. I thought about drilling it out but the locks are not apparently available for replacement. Any experience would be appreciated.
My door is very far gone with rust and I'm sure I will be in need of one and at least one hinge from what I can tell with door still closed.
This is on a very original 72 Sierra Grande that I will be doing a complete restoration on and a hate to loose that option as the truck is loaded with options.
Red71gmc is offline   Reply With Quote
Old 10-28-2018, 12:22 PM   #2
jocko
jocko's Avatar
Re: Bedside tool box with no key
If you haven't done so, recommend PM member LockDoc.
Old 10-28-2018, 08:13 PM   #3
AussieinNC
Moderator
AussieinNC's Avatar
There are various styles of lockbox locks available...try looking on amazon first to check if the style is available...
lockdoc may have better suggestions, but it may be a drill it out and look for replacement...
Some of these locks are retained by a simple thin steel wave plate that can be bypassed by jemmying on the lock itself....
Post a pic of the lock for us to review...
Family and country before all others...
2006 Chevy Silverado (Daily Driver)
2012 Chevy Equinox
AussieinNC is offline   Reply With Quote
Old 10-28-2018, 09:23 PM   #4
hjewell2
hjewell2's Avatar
if there is a number that you can see on the lock core , that would be the key code and a locksmith can cut you a key by that code.
hjewell2 is offline   Reply With Quote
Old 10-29-2018, 06:37 AM   #5
rpmerf
rpmerf's Avatar
A good locksmith should be able to pick it. Once it is open, you should be able to remove the lock cylinder and have the locksmith make up a new key for it.
1970 C20 Custom Camper - 350, TH350
1997 GMC Suburban
1994 Acura Integra GSR
1987 Dodge Daytona Shelby Z
rpmerf is offline   Reply With Quote
Old 10-29-2018, 08:46 AM   #6
Shinysideup
Shinysideup's Avatar
X2 ,quite easy.
._____________
..\ .___ . . . . _ . .\. . . . . . . . . . . ___
..| /_+_/ ___ |o| ...}. . . . . ______i__!\____
. [_____(O)_|_'|__}>-------[-_(O)__i'___i (O)-]
Originally Posted by 68 P.O.S. View Post
No thank you on that lifetime warranty. I don't want a turd for life.
Shinysideup is offline   Reply With Quote
Old 10-29-2018, 10:02 AM   #7
LockDoc
The Older Generation
LockDoc's Avatar
You are pretty much out of luck on it if you don't have the key. Be sure and spray the inside of the lock with a good penetrating oil and try your ignition key. Insert and remove it a few times to loosen up the tumblers. If the key will slide into the lock it may work. (don't force it) Even if you can get to the latch you can't retract it because the locking system has a dead latch that keeps the latch bolt from retracting until the key is turned to the unlocked position. Like Auissie said there is a spring clip that holds the lock cylinder in the door. If you could get to that and slide it off, the lock cylinder will come out. (See picture below) If you go that route be sure and spray the clip before trying to remove it.
In the picture the lock is in the unlocked position. When locked the tab turns and blocks the lock bolt so it can't be retracted when the handle is pulled.
GM sidebar lock cylinders (1935 and up) are almost impossible to pick. I have been a Locksmith since 1977, specializing in antique autos and motorcycles and I can count on one hand how many GM sidebar locks I have been able to pick, and that was because they were almost completely worn out. If there is a code number on the lock case that would make it easy, but you have to have the cylinder removed to see that.
Originally Posted by Shinysideup View Post
X2 ,quite easy.
See above....
LockDoc
Leon
Old 10-29-2018, 10:12 AM   #8
tdangle
tdangle's Avatar
If the door is gone anyway, maybe it makes sense to cut the door open to try and save the lock assembly. Just a thought.
Terry
1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC
tdangle is offline   Reply With Quote
Old 10-29-2018, 01:54 PM   #9
KJSR
KJSR's Avatar
Great advice....I was thinking the same thing
1936 Chevrolet 1/2t
1964 Chevrolet C10
1964 Chevrolet C10 (sons)
1965 Chevrolet K10 Suburban
1969 Chevrolet C10
1937 Plymouth P4
KJSR is offline   Reply With Quote
Old 10-30-2018, 08:31 AM   #10
Red71gmc
Thanks LockDoc. That's what I needed to know.
Tdangle you have a good point. I believe that would be the best angle to take. Try and save the latch and lock and replace the door. The bottom of the door is badly deteriorated with rust so I can probably just cut around the hinges.
Old 10-30-2018, 08:33 AM   #11
Red71gmc
062500hd, if you have access to a new setup pm me. Thanks
Old 10-31-2018, 12:00 AM   #12
tdangle
tdangle's Avatar
Not to hijack this thread, but is it possible to have all locks using only 1 key? I have the original key for the toolbox, a new square head key for the ignition and new round head keys for the door locks.
Terry
Old 10-31-2018, 12:19 AM   #13
Red71gmc
LockDoc would be your guy on that.
I have a 71 with different keys for the ignition and door locks. This 72 has the same key for the ignition and door locks but does not work for toolbox.
What I have read from the different threads, some of the toolbox keys are the same as ignition and others aren't.
Old 10-31-2018, 09:37 AM   #14
LockDoc
LockDoc's Avatar
The doors and ignition were keyed the same on all '67-'72 GM trucks, from the factory. The glove boxes and tool box doors may or may not match the other locks....
PM sent.
LockDoc
Leon
Old 11-04-2018, 11:42 PM   #15
Custom/20
Custom/20's Avatar
Since the bed side tool box liner is fiberglass you could drill a hole on the bottom or the side and use a large screw driver or pick to knock the clip out to release the lock cylinder. just put pop in a hole plug once you're done. just a idea.
Custom/20 is offline   Reply With Quote
