Old 12-12-2018, 09:14 PM   #1
Putzer
Transmission mount cross member help
Good evening all. Shown in the pictures is the ece trans mount. I have read multiple accounts where people have had the same setup as I do, lq4 w/ 4l80 and the holes line up. Seems like my trans is sitting back further than most.
Does anyone see issues with what I've got going on? Engine mounts etc.
Thanks!
Putzer is offline   Reply With Quote
Old 12-13-2018, 01:53 AM   #2
72MARIO
72MARIO's Avatar
Re: Transmission mount cross member help
Looks like you can slide your engine way back if you want to.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 12-13-2018, 08:07 AM   #3
Putzer
I can slide it back but then it's even worse off. It needs to go forward about an inch and a half to line up with the last set of holes. If I were to push it backward, one hole would line up and then I'd have to drill a couple new holes. Not a big deal but since ive seen this done without having to drill new holes, i'm worried there's something I'm overlooking.
Old 12-13-2018, 08:58 AM   #4
mongocanfly
mongocanfly's Avatar
Be allot easier to tell engine position if the cab cab was on..I'm assuming there's no movement left in the engine mounts to go forward...
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 12-13-2018, 09:34 AM   #5
Putzer
unfortunately I sent the cab off to have replacement panels done. I have no welding experience, equipment or space. Yeah, the engine is maxed out forward.
Old 12-13-2018, 02:00 PM   #6
First c10
First c10's Avatar
I used the same trans mount but used the ECE motor mounts and it fit great but 1 hole. It was off about 3/8" so I just drilled the frame basically putting a slot and bolted it right in.
The best thing is to make sure your not going to hit the firewall or are to far away from the firewall. Best to have the motor positioned correctly in relation to the firewall and just drill the frame to bolt everything in. Hope this helps! Oh and my swap was a 6L80 trans
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 12-13-2018, 02:05 PM   #7
First c10
First c10's Avatar
if you need to move motor/trans forward can you just swap motor mounts???
GO GO!!!
