Old 11-17-2023, 10:53 PM   #1
jdime20
Van column lower bearing
Does anyone know where I can find this setup fir a 3/4 shaft? Everything I find and have ordered shows up with a 1" id. Pretty sure the column is a 70-72 van
jdime20 is offline   Reply With Quote
Old 11-18-2023, 09:58 AM   #2
70shortfleet
70shortfleet's Avatar
Re: Van column lower bearing
If you but this lower bearing kit, it has the correct bearing for you
https://www.ebay.com/itm/12424476056...Bk9SR-bBuav8Yg
70shortfleet is offline   Reply With Quote
Old 11-18-2023, 10:47 AM   #3
jdime20
Thanks, ill order it and use the parts from the other bearing kit. How about the shift lever up by the steering wheel? I'd like to find some kind of machined aluminum lever to match the tilt/turn I have, bit everything I find says it does not fit van columns. Tje end is machined different. I thought these van columns were the one everyone wanted and turns out there the hardest to find anything for
