![]() Join Date: Nov 2018
Identifying heavy duty vs not heavy duty brakes
Last weekend I snapped up a 1970 C10 long-bed step side. It was a father-daughter restoration project that was mostly complete, but they need to sell. There is not a spec of rust on this truck, it's been repainted, new interior, lots of other new parts. It has the extra load springs, also. 250 CID, 3 on the three.
It's got an Offenhauser 3 carb intake, along with 3 TMC 1-123 carbs for it. To get it finished, I need to install the carbs, battery, inner wheel wells (came with those), front and rear bumpers (came with), bed (need to get a bed kit), and do the brakes. Which gets me to the point of the question... Autozone and a few other places have wheel cylinders, but have both heavy duty and non-heavy duty cylinders. Is there something that identifies which the truck has? One of the front ones is leaking, and the brake hardware is a little rusty and gunky in that wheel, so I'm planning on new cylinders, shoes, and hardware for the front. The back brakes are dry, and the hardware is decent. Any advise for a newly minted C10 owner? Link to albumn w/ pictures Last edited by jcwren; 11-16-2018 at 10:19 PM. |
Re: Identifying heavy duty vs not heavy duty brakes
Pull one off and take it with you to compare.
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 |
I dont remember off hand but heavy duty brake pads I think where wider then standard. I think 2 inch wide but could be wrong , also I would replace all the hardware when doing a brake job the hardware Kit is cheep and worth replacing
![]() Join Date: Aug 2012
Standard drum brakes are 2 inch wide. The heavy duty brakes are 2 3/4 inch wide and can be found on 76 to 87 and 10 bolt rear end K series rigs.
It's a fairly simple swap to do if you have the standard drums and want to change to the later heavy duty version. I recently had my rear end refurbished and upgraded the brakes to the heavy duty version at that time. |
![]() Join Date: Feb 2010
Location: Falls City, Nebraska "100 Miles From Nowhere"
Thats a clean old stepper! I'm "Ironangel" from the 67-72 GM Truck Board...I was wanting to get a peek at the rear axle and suspension. And maybe a front brake assembly with the drum removed? Also take pic of the "SPID" (Service Parts Identification Label) and it will note the heavy duty options added. Leaf Springs are an option, fleet vehicles, state and government vehicles were often HD optioned...Cool truck! Pull the drums and measure the brake shoe width
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" ![]() "Be American, Buy American" ![]() |
#6 | |
#7 | |
The rear brakes on all the pickups till 73 (yes 73 is the first year square body) are all 2" wide, 11" I.D. drums... I believe this started in 1960, not remembering well, I didn't sell much 60-66 stuff. There WAS a heavy duty option from 67-72 for the front drum brakes. I never sold the HD shoes, EVER for a pickup, BUT towards the end of my parts store days (1985-1998) a friend came in for front shoes for his Suburban. IT DID have the heavy duty brakes on it. I've never seen them before or since. I'm guessing the HD brakes were most likely only mostly on Suburbans... Every time I looked up the front brakes for a 67-70 pickup and asked what size the shoes were, I wondered for a long time IF any pickups came with HD front brakes, seemed like I was wasting my breath asking about shoe size. There;s folks here that swear that the front drum brakes are adequate for any stopping situation, I STRONGLY disagree. Front disc brakes are SO much better!!! You don't need to go crazy with disc on the back, the factory front disc setup is awesome!!! The heavy duty rear shoes started in 1974, you could get either the 11X2 shoes. OR the 11-5/32 X 2-3/4 shoes on the rear, depended on how the pickup was ordered. The rear HD drums are also different, You can change to HD rear drum brakes, BUT, BUT you must also change the backing plate, no other way to do it... Last edited by 68Gold/white; 11-21-2018 at 02:17 PM. |
