Old 09-29-2010, 09:55 PM   #1
Born Lucky
1964 Heater
As I go through my truck, fixing this and that. I am about to look into my heating system. I have the basic heater for my 1964.
What I want to know is how good does the system work. At the present moment it does a terrible job heating and defrosting. What can I expect?
The way it is I would need a supplement electric heater for the winter.
Born Lucky is offline   Reply With Quote
Old 09-29-2010, 10:36 PM   #2
64GMCHorsepower
Justified!
Re: 1964 Heater
Mine didn't work worth a squat. Plus on most of these trucks, there was no insulation, holes everywhere where grommet were gone....it's like a big wind tunnel.....
Chad
1964 GMC Fleetside Shortbed....350/700R4 tranny
64GMCHorsepower is offline   Reply With Quote
Old 09-30-2010, 12:17 AM   #3
Captainfab
60-66 Nut
Re: 1964 Heater
There were 3 different heaters offered. It sounds like you have the recirculating heater. Those don't work worth a crap in cold climates. Is your heater completely under the dash, with nothing in the engine compartment? If so you may want to look into upgrading to either the Thriftair or the Deluxe heater.
Old 09-30-2010, 06:47 AM   #4
Born Lucky
Re: 1964 Heater
The heater core and motor are secured on the fire wall and the rest of the unit is in the cab.
Old 09-30-2010, 07:29 AM   #5
5264chevytrucks
Re: 1964 Heater
I was having the same problem that you were. I changed the heater core out on my 64. It has the exact same style that you have. Once I changed it out, it would roast me out of the truck. The heater core is inexpensive. You can get one at advance, napa, autozone... It is a 30 minute fix. Just open the top of the heater core box in the engine bay, and you will easily be able to see how to take it out. I would also, once I have the heater core out, clean out any debris in the box. I had a bunch of leaves and dirt in mine. This resticted the air flow.
5264chevytrucks is offline   Reply With Quote
Old 09-30-2010, 07:38 AM   #6
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Re: 1964 Heater
94788 heater core from Spectra Premium.
Old 09-30-2010, 10:56 AM   #7
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: 1964 Heater
I just tried out my heater the last week for the first time and had to say I was surprised it worked well. Granted we don't get that cold but was surprised the 3 speed fan work, the vents switched (manual lever under dash to switch between floor or defrost) fine. Actually happy it's something I don't have to mess with.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 09-30-2010, 11:02 AM   #8
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Re: 1964 Heater
Who needs heat? LOL
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 09-30-2010, 12:18 PM   #9
JimQ
JimQ's Avatar
Re: 1964 Heater
Just finished getting my Deluxe heat up and running. I picked up the truck this summer and the heater was a disaster.
All 3 levers were broke off the controller. The blower motor switch was bad. The blower motor resistor was bad. All 3 cables were pretty well frozen. AND the duct work to the defrost vents was trashed.
After about $80 and a few hours work, she works like a champ. I love these old trucks!
Q
'64 K20 327
JimQ is offline   Reply With Quote
Old 09-30-2010, 07:05 PM   #10
Born Lucky
Re: 1964 Heater
Q
Tell me how you spent $80.00.
Everytime I told something it costs well into $100.00 or more.
Old 09-30-2010, 08:50 PM   #11
protrash64
Resistance is Futile
protrash64's Avatar
Re: 1964 Heater
Born; I would check the air flow/ leak situation as mentioned earlier. My 'burb has the deluxe heat and in winter (not that cold) it cooked me in about 5 minutes of driving. I'm sure it would work well in colder areas.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 09-30-2010, 08:57 PM   #12
lakeroadster
Re: 1964 Heater
What can I expect?
I have the same heater as you and it is more than adequate. If the fan is working and the manual defrost / heater flapper is working the only thing left is to pull the heater core and get it checked. If it's bad, repair or replace.
Hope this helps!
lakeroadster is offline   Reply With Quote
Old 10-02-2010, 12:04 AM   #13
bubba327
HOW long until spring??
bubba327's Avatar
Re: 1964 Heater
I had the thrift-air core in the 64.( it was leaking and needed replaced) I found the deluxe core is bigger and fits by simply removing the extra width in the heater box. The notch is already cast in the aluminum. I used a die grinder to trim things up. No other changes are necessary to accommodate the bigger core. The hose fittings are identical.
Lots of heat coming out now.
My local independent parts house had it on the shelf but it had years of dust on the box.
69 chevelle convertible
71-C-10 short-wide and low
64 C-10 custom shortbox "Bubba"s Recycling project"
bubba327 is offline   Reply With Quote
Old 10-02-2010, 12:43 AM   #14
Captainfab
60-66 Nut
Re: 1964 Heater
Were you able to still use the little factory support bracket on the heater core tubes? They look a little different on the new core.
Originally Posted by bubba327 View Post
Attachment 639003
Old 10-02-2010, 06:26 AM   #15
Born Lucky
Re: 1964 Heater
Attachment 639003
Wow big size different!
What are the dimensions of the deluxe heater, so I can compare.
I plan on looking into this heater situation soon as winter nears.
Old 10-02-2010, 09:42 AM   #16
bubba327
bubba327's Avatar
Re: 1964 Heater
Thriftair core is 7 1/4" L --6 3/8" W -- 2 1/2" H
Deluxe core is 9 1/2" L --6 3/8" W -- 2 1/2" H
I believe these dimensions were found in the LMC catalog
The factory original saddle support straps were re-used on the new core.
Two new 1/8" holes did need redrilled for the strap mounts
I recall using some high temp silicone caulk for cushion/adhesive on the straps around the tanks.
Have some more pictures over in my build thread "bubbas recycling project"
http://67-72chevytrucks.com/vboard/s...65170&page=6Os
post # 127 and 132
Old 11-23-2011, 11:16 PM   #17
Touchdown67
Touchdown67's Avatar
Re: 1964 Heater
Q
I am re doing my Dlx. Heater and I was wondering if you can tell me where you found the resistor?
Thank you,
Touchdown67 is offline   Reply With Quote
Old 11-23-2011, 11:20 PM   #18
trevota
Re: 1964 Heater
my basic heater works awesome!
trevota is offline   Reply With Quote
Old 11-23-2011, 11:48 PM   #19
rustyrodknocker
Re: 1964 Heater
my burb gets warm when your just about there. several years ago i put a new fan for a square with ac in my father inlaws 70 burb. that thing changed everything. somebody I worked with recommended it. been wondering about putting one in the 66.
rustyrodknocker is offline   Reply With Quote
Old 11-24-2011, 12:12 AM   #20
Rich 5150 69
Rich 5150 69's Avatar
Re: 1964 Heater
Thank you,
LMC carries the resistor.....
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 02-15-2013, 09:25 AM   #21
64LBSS
Re: 1964 Heater
Hey folks, new here.. Curious if someone could explain the specific differences in the different heater setups. I believe mine has a basic heater, I re wired temporarily with a one switch, fan motor only adjustment.. I've scavenged the deluxe controls I think.. Just looking for some insight.
64LBSS is offline   Reply With Quote
Old 02-15-2013, 02:13 PM   #22
63burban
Chevy addict
Re: 1964 Heater
Flush out with the garden hose or blow out the heater core with compressed air. Make sure your ducts are clear of debris and the defroster hoses are good. Make sure you blower motor runs nice, if not install a new motor. There isn't much to these heaters no matter which system you have. Just adding a little WI winter knowledge.
63burban is offline   Reply With Quote
Old 02-15-2013, 02:36 PM   #23
da_bears_da1
Re: 1964 Heater
I have the thriftair setup on mine. I am building a custom truck with lots of chrome on the engine. I like the clean look of the basic heater that is in the cab with nothing on the firewall. Don't need much heat since i plan on just going to shows and meets with it. Any idea where I can get the basic heater setup?
da_bears_da1 is offline   Reply With Quote
Old 12-20-2018, 11:37 AM   #24
7shotguns
I have a 1966 c10 and when I turn the heater on it have a bunch of dirt and debris blowing out of my vents. How can I stop this. Same thing happens when I open the side vents below my dash in the summer. Please help
7shotguns is offline   Reply With Quote
Old 12-20-2018, 12:37 PM   #25
PGSigns
PGSigns's Avatar
Re: 1964 Heater
You should start a new thread and put your problems in the title. It will get a lot more response. To help with the problem you have Pull the cowl cover (the slotted panel the your wipers come through)off the truck and clean out under it. Next take the top off the heater box under the hood and clean it out. Last take the shop vac and vacuum out behind your lower vents in the cab. The bottoms of those have been known to rust out and be open to the eliments.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
