Old 01-30-2019, 09:46 PM   #1
HalfCaseKustoms
Jingle sound from rear drums...
71 with factory style front disc and rear drums. When I go over a bumper while while applying any kind of brake I get a jingle sound from the rear brakes. Does not make sound if brakes are not applied. I have had them apart multiple times and cant figure out what it is. Brakes work fine. It's driving me nuts!! Help
HalfCaseKustoms is offline   Reply With Quote
Old 01-30-2019, 10:11 PM   #2
Grumpy old man
Grumpy old man's Avatar
Re: Jingle sound from rear drums...
exercise the emergency brake ,the strut bar spring can get lazy and the strut bar will jingle ,jangle and see if that helps .
Old 01-30-2019, 10:44 PM   #3
RUN GMC
RUN GMC's Avatar
.....also check emergency brake cable underneath they do that when not tight or connected.......
RUN GMC is offline   Reply With Quote
