Old 02-02-2019, 11:48 AM   #1
Aggie1998
12-bolt axle length
I have a 70 c10 with a 12-bolt rear end. The length of the rear end and the stamped code indicate that it is the wide rear end. I want to convert it to 5 lug axles. Can I just buy replacement axles for a 70-71 c10? What length axles do I need?
Aggie1998 is offline   Reply With Quote
Old 02-02-2019, 02:27 PM   #2
Zeroman
Zeroman's Avatar
Re: 12-bolt axle length
The only real way to be sure you get the correct axles is to remove your current axles and measure them.
I am also in Cypress. I am sending you a PM.
Zeroman is offline   Reply With Quote
Old 02-02-2019, 03:03 PM   #3
rjs53
Measure from the wheel mount surface, outside flange you brake drum goes up against to the very end of the axle. It should be about 31.5" if its the wider axle. If not its the shorter at 30.5"
2003 Dodge 2500
1969 C10
2014 Camaro SS/RS/1LE
rjs53 is offline   Reply With Quote
