![]() Join Date: Aug 2014
What is a dimple?
I am trying to figure out how to install PS on my 67 K10 with a 292. As a result I am still confused as to how to do this, but in addition I keep reading about dimpling the frame. What does that mean and how is is done. Any photos? I am not sure I even need to do it. Not sure if I can actually put PS on this truck. Thanks, George
1972 Chevy Custom Deluxe Highlander, owned 34 years. 1970 GMC Sierra Grande 2500, unrestored, original. 1970 Chevy K10 Short Wide-bed, working on restoration.. 1967 Chevy K10 Short Stepside, unrestored original. 1969 GMC CST (Longhorn) 396, buckets, unrestored. 1995 GMC K2500, 65,000 miles, 454. |
![]() Join Date: Dec 2009
Re: What is a dimple?
Here's an old thread on the subject.
Link: https://67-72chevytrucks.com/vboard/...eering+on+a+67 Hope this helps.
________________________________________________________________________________________ ____________________________________________ The early bird gets the worm, But the second mouse gets the cheese 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
#4 | |
LOL! |
#6 | |
The pump mount on the motor is hard to find if you don’t have one already.
This guy on eBay has conversion brackets if you need them. https://www.ebay.com/sch/i.html?_fro...ckets&_sacat=0 |
![]() Join Date: Feb 2016
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
Project Junkie! Fishing Poor!!
![]() Join Date: Dec 1999
On the 67 4X4 you can space out the gear box. The pitman arm swings front to back and the center is un-effected by the spacing. the 2WD truck gear swings left to right and spacing the gear off the chassis does effect the centering of the gear. WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
#10 | |
![]() Join Date: Feb 2002
K/ Trucks are a whole different animal. '67 + '68 used Power Assisted Steering on 4X4 models. This system is also used on vintage Corvettes so the parts are priced thru the roof. The MY '69 and later power steering gear boxes swing left/right. The '67/'68 and earlier K/10 steering gears swing fore and aft. System types are incompatible. I tried putting on a '69 Power Steering Gear box on my Sub, and had no end of problems. Steering geometry was way off. I had to make a 180* from the middle lane to get the curb lane on the other direction. The 1/2'' mounting bolts Holding the gear box to the frame would shear off sometimes. Rack to rack alignment was off. When I went back to manual steering [after JB welding a crack in the manual case] it still would not track right, since we had cut the draglink and used a variable 1 ton draglink in its place. Easiest solution is Don't Do it. Next best solution is change out the front axle/differential assembly for '69 and later- Dana 44. That will give you P/S and Power Disc Brakes. Been there done that and it was not fun. Two wheel drives, it might be easy, but not on a K/ Truck. And I never mentioned how hard it is to find a 292-only P/S Pump bracket.
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 04-18-2022 at 10:52 PM. |
#11 | |
