Old 02-03-2019, 02:44 PM   #1
macs61
Torsion bars
Hi guys I am doing a front end rebuild and wonder if anybody has removed the torsion bars from the bottom a arm any help greatly appreciated. 61 c10 complete rebuild front to rear. Thanks Walter
macs61 is offline   Reply With Quote
Old 02-04-2019, 09:34 PM   #2
LVPhotos
LVPhotos's Avatar
Re: Torsion bars
Lots of penetrate like PB Blaster, WD Penetrate, Kroil. 2lb hammer, big drift pin or like.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 02-04-2019, 10:28 PM   #3
macs61
Re: Torsion bars
thanks for the info i will try that did you remove them before or after the a arm was removed thanks Walter
Old 02-04-2019, 11:02 PM   #4
LVPhotos
LVPhotos's Avatar
Re: Torsion bars
Before a arms. Tire at full droop, jack on pork chop, remove bolt, release pork chop. Punch bar out of arm.
Old 02-05-2019, 12:03 AM   #5
macs61
Re: Torsion bars
Thanks will go at it tomorrow.
Old 05-04-2019, 07:18 PM   #6
mailman
mailman's Avatar
Re: Torsion bars
Did you get the bars out of the A arm?
mailman is offline   Reply With Quote
