Old 05-04-2019, 06:53 PM   #1
68bowtie
68bowtie's Avatar
HO52/HO72 question
How do I get the oil seal out of the hub? I’m trying to replace them without damaging the inner bearing. I’ve searched through all the Eaton threads I can find on the forum, and I have a chassis manual, and the most detail either has basically says to “pry it out”.
Old 05-05-2019, 06:08 AM   #2
Re: HO52/HO72 question
I have never owned a seal puller. I always knock the race out from the front with a drift punch tapping it around the circumference to work it out.
Old 05-05-2019, 09:52 AM   #3
72c20customcamper
72c20customcamper's Avatar
Price of wood dowel broom handle whatever fits gently tap the bearing out . The deal will pop out to. I just did mine this way ,the seal puller I have was to small
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 05-05-2019, 10:11 AM   #4
68bowtie
68bowtie's Avatar
Ok good info. The inner bearing has a smaller ID than the seal but I suppose I can tap both out carefully from the front side. Seal puller, genius idea...
Old 05-05-2019, 01:47 PM   #5
There's just enough lip to set against to tap out. So be careful if you use a drift punch.
